Question about Arris SURFboard SBG900 (49402201900) Modem
Is there a way to change my DNS number on my Motorola SBG900 modem?
How do i turn wifi off surboard sbg6580
log in to the modem as if you were going to change the wireless password (browse to default gateway and enter username and password) then turn off SSID broadcast (usually by un-checking a box)
try these
SBG900 Default IP:
192.168.0.1
SBG900 Default Password:
motorola
SBG900 Default Username:
admin
Nov 19, 2013 | Arris SURFboard SBG900 Wireless Router...
Hi.. I have just been connected to cable broadband with a Motorola Surfboard SBG9001 modem. I don't have any security, how can I change that so that the neighbours get free internet. Thanks
Open Internet Explorer and type 192.168.0.1 in the location for a web address.
When the SBG900 page appears choose WIRELESS on the left.
When WIRELESS appears click SECURITY AND stay on the basic page.
Choose WPA as the SECURITY MODE.
Use your phone number as your passphrase
Under the WPA CONFIGURATION section choose TKIP and LOCAL WPA-PSK.
Then click SAVE CHANGES.
The SBG900 may restart before the changes take effect.
May 17, 2011 | Arris SURFboard SBG900 Wireless Router...
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
SBG900 WITH WRONG PROVIDER SETTINGS HELLLPPPPP
Here is the complete manual.
http://broadband.motorola.com/consumers/products/sbg900/downloads/sbg900_user_guide.pdf
You want page number: 22
This is the Wizard mode that asks you questions and configures the Modem.
This is a great Cable modem, by the way.
Please rate this solution!
Jul 03, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SBG900 settings set back to default settings
This exact problem just happened to me today. I called Motorola & they said this sometimes happens as a result of a power surge (can be on the cable or power lines). All settings were lost & I had to redo the entire set-up from scratch.
Jun 29, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SBG900 Connected but not sending and recieving.
its your modem dude.... try to connect it to your main connection..
Jun 16, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Wep key
Try admin for the username and motorola for the password.  The default SSID is Motorola.  Here is the pdf with all of this info.
http://broadband.motorola.com/consumers/products/SBG900/downloads/SBG900_Quick_Install%20_Guide.pdf
Apr 24, 2009 | Arris SURFboard® SB5101 Cable Modem
SBG900 doesn't go online
I have the same modem/router. I had the same problem. I had to call my service provider and they had to put the modem into the system so the ip address would so up correctly. You need to call them and tell them what kind of modem you have. Have the model number and serial number ready to give them. They will have to make some adjustments on their end and they will most likely tell you to reset your modem. After that it should work fine. My worked fine after I talked to them and they made their adjustments. I hope this helps you.
Jan 05, 2009 | Arris SURFboard SBG900 Wireless Router...
Motorola modem SBG900
you must define DNS and Gateway!!! Go on My Network Places, right click, again right click on your network, select properties, TCP/IP and in there enter needed IP addresses!!!
Jan 25, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 (49402201900) Modem Logo
273 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
