Question about Brother Multi-Function Center MFC-8870DW All-In-One Laser Printer
FUSER ERROR ON MFC 8870DW BROTHER - Brother Multi-Function Center MFC-8870DW All-In-One Laser Printer
jtuminaro
  • 56 Answers
SOURCE: Replace Fuser error will not go away
With in 2 seconds you have to hit Menu,*,2,8,6,4
Continue even though you hear the 3 beeps.
When it does into maint mode press 88
That is parts counter reset
Scroll to the part and hit ok.
Press 99 to exit Maint mode
Posted on Jan 15, 2009
  • 1056 Answers
SOURCE: Replacing Brother MFC-8440 Fuser
To remove the fuser - remove the tray at the bottom and the back tray (4 screws, 2 either side) lift out the phone line box on the right (looking from the back - 2 screws) and swing it out of the way (careful as cable isn't too long) 2 screws either side of the fuser (long black object at the bottom) unplug the halogen lamp (white plug on left) and small 5 wire plug on right, and lift out fuser unit.
Posted on Aug 28, 2008
SOURCE: Fuser replacement on Brother MFC 8860DN
Yes I did it myself, however I am savvy with most hardware, I wouldnt suggest it for the novice. It cost around $NZ245 for the fusing unit, which from doing a quick search online is about the same in most countries.
Posted on Sep 03, 2008
  • 114 Answers
SOURCE: MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
Posted on Jul 21, 2010
  • 42 Answers
SOURCE: My brother MFC 8860DN printer
Open it up from the back of the machine. Try reseating the fuser first. If that does not help, then you need to replace it. Probably the ceramic fuser element is going bad? It is either not heating up fast enough or heating up too fast. If you can print test sheets, and the text is too shiny, it would be a fuser that is too hot. If you can rub the text off the test sheet, it is not fusing fast enough and there is not enough heat.
Try ebay for a fuser. They are fairly simple to replace.
Posted on Oct 13, 2010
Machine error code 55
Sir/madam
Please Follow the Video http://www.youtube.com/watch?v=xig75RXA5qc For Your Printer Brother Troubleshoot
Or Follow Us For On Brother Printer Support
Jan 23, 2014 | Brother MFC-8870dw Wireless Multifunction...
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
Wrinkled copies
Fuser unit is about the only thing in this model of printer that WILL cause wrinkling/creasing of the paper. So most likely, yes you are going to need to replace the fusing assembly.
Part# LU0214001K
About a $179.00
The vendor I use is precisionroller.com
Good Luck
Mar 04, 2010 | Brother Multi-Function Center MFC-8870DW...
I have a mfc 8870dw and just replaced the toner now it displays "toner error" what can i do
Remove and reinstall the cardtridge.
Check manual for new cardtridge code (if needed).
Nov 17, 2009 | Brother Multi-Function Center MFC-8870DW...
8870DW scan function does not work with macBook using USB
You must reinstall the software on the computer to which the printer is physically connected. i think u are using usb to connect to computer so to share it out u most buy printserver or use let the computer where its physically connected just to be on and u share there the computer to your workgroup computers
Dec 27, 2008 | Brother Multi-Function Center MFC-8870DW...
Dec 14, 2008 | Brother MFC-8870dw Wireless Multifunction...
Resetting "Replace PF Kit 1" message
Same with me on my MFC 8870DW. The procedure worked perfectly:
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer.
But how do I know whether or not I really NEED to replace a PF Kit1? I guess I'll find out if it recurs soon.
Joe
Jun 18, 2008 | Brother MFC-8460N Laser Printer
Brother Multi-Function Center  MFC-8870DW All-In-One Laser Printer Logo
493 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
