Question about Cobra 150 GTL DX Base CB Radio
My radio recieves ok but only whistles when i key the mike is this a major fix?
    Guru:
  • 773 Answers
Do you have talkback installed? It my be too loud and causing feed back. Back the mic gain down if so.
Could also be improper mic wiring. If you use a mic that is wired for a different radio, it could just cause a hum, buzz or squeal.
Another thing that can cause a hum, buzz or squeal is a faulty volume and or squelch knob depending on the radio.
  • Turn down or disable talk back.
  • If you cannot turn off or disable talk back, lower mic gain.
  • Try a different mic that you know is wired for cobra.
  • Play with volume and squelch knobs while TX and see if it stops at all. If it does replace knob.
Posted on Oct 13, 2010
Sqeel in tramission when mike is keyed
Check your antenna connections. This type of feedback is many times caused by a bad connection or an antenna which is mismatched to the radio.
Best regards.
Dec 07, 2012 | Cherokee CBS-500 (40 Channels) 2-Way Radio
Just got a Galaxy DX 2547. Barefoot works GREAT. Problem: When connecting to my linear (Texas Star 667V) rig fires up AOK on AM but on SSB it has issues driving the amp. SWR is OK Radio SSB output ~...
Have you tried turning the mic gain up,and not knowing Texas star model numbers,is it a mobile linear,if so,do you have a sufficient power supply?Just some thoughts off top of my head.
Aug 22, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
We find ourselves on the Alaskan Hwy, at Ft. Nelson. Yesterday we noticed a whistling noise coming from what appears to be brake compartment and when you apply the brake or turn the steering wheel, it...
A whislting noise would make me suspect a cracked or broken vaccuum line. Whistling as it sucks air into the system. I would check the biggest one first, on your brake booster. It is a large line coming from the engine to the brake booster assembly located behing the brake master cylinder. I would check all the lines with engine running, have a helper rev the engine slightly while you listen in the engine compartment to see if you can locate it. Also work the brakes simultaneously. Cold weather can make older lines crack which can cause a serious problem depending on which line cracks or breaks. Check all your air lines first and see if you find it in that system before assuming something more major. A crack in other engine system lines will usually produce a fluid leak of some type.....Good luck!..Mike
Jun 19, 2011 | Dodge Ram 3500 Cars & Trucks
Radio worked fine when bought 2 days worth went to key up mike only sound is a sustained whistle sound,took to repair shop had fixed guy said he rebuilt talkback worked again 2 days same result sustained...
Do it have a relay mod for the talkback if so take that thing out. use the normal talkback. We are in TX.. no charge to check out.. I would check to make sure it has just plain normal talkback, and no other mods done first.. any other mods done??
Mar 19, 2011 | Connex Radio Communications
Hi I have this cb installed in my jeep, did it myself. All is hooked up properly and xxchecked. It turns on, and all the lights work, meter and channel lights are on. Squelch isn't working and which told...
Hello Frankie.
Your diagnosis is correct. Pull it out and return it while it is still new. Do this asap so amazon doesn't give you a difficult time. Joe
Thanks for choosing Fixya!
Jan 07, 2011 | Midland 1001LWX CB Radio
The radio will recieve but will not talk. The needle does not move when keying the mike. I have tried several mikes but nothing seams to help.
fried finals maybe? you may want to chk buffer /driver and final transistors for errors do you have the same problem for am/fm and ssb?
Dec 16, 2010 | Cobra 150 GTL DX Base CB Radio
Superstar 3900 with no USB or LSB on receive.
most likely been fiddled with and out of alignment. If you have a freq counter and a volt meter you could possibly fix it yourself. look at cbtricks.com for the aligment procedure.
Jun 13, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Uniden 520xl makes humming noise when mike is keyed
if you have a power mic , you might have it turned up to high. next make sure you have a good ground on your antenna. if that is ok and you still have the same problem have the swr checked. this should fix the fm radio noise.
Apr 10, 2009 | Uniden PRO510XL 40-Channels Base CB Radio
Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Aug 15, 2007 | Galaxy Radios DX-66V Base CB Radio
Cobra 150 GTL DX Base CB Radio Logo
187 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
