Question about Ricoh Office Equipment & Supplies
Can i reset the error code sc 320 - Ricoh Office Equipment & Supplies
  • 126 Answers
Sc 320 is the laser error. the polygon mirror motor is faulty in laser unit and it can only be solved by replacing the polygon mirror motor. there is no other solution.
Posted on Nov 05, 2010
4 Suggested Answers
bowdo
  • 78 Answers
SOURCE: LANIER 5618 COPIER ERROR CODE SC-320
Yes this is a Polygon Mirror motor error it is reasonably common in the Lanier digitals. The mirror motor can be ordered separtetly to the laser unit.
Posted on Feb 12, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Ricoh Aficio error code sc 320 what is this and how can I fix it.
Polygon mirror motor error/lock. Unplug the copier. Wait 20 seconds. Plug it back in. See if that makes it go away.
Otherwise you should get a hold of a service technician but getting parts for a 250 is very tough. It could be the polygon motor, the power supply, a cable, or a board. It will take some time to troubleshoot.
Posted on Oct 31, 2008
  • 183 Answers
SOURCE: error code sc 320
polygone motor error in laser unit change it possibe causes cutting wires between polygone motor and ld unit
Posted on Jan 06, 2011
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
MY GESTETNER 3218 AFICIO FUNCTIONAL PROBLEM SC 320. HOW CAN I SOLVE THE PROBLEM
SC 320 - Polygon motor error.
The polygon motor does not reach its operating speed within 10 sec. after the polygon motor on signal,or the lock signal is not detected for more than 40 ms continuosly during operation.
Possible causes polygon motor defective,poor conection of the interface harness which connects the polygon motor driver and the IOCSS board, IOCSS bboard defective.
The SC can be reset by turning the main switch OFF and ON if the SC was caused by a sensor error.
To reset SC press yellow key 1 - 0 - 7 and STOP ( red ) key for 3 seconds,enter in the SP mode, enter SP 5-810 ( SC code reset) and select "1".Then hold down the Photo mode key and the # key at the same time for at least 3 seconds(this does not require the main switch to be turned off and on).
Aug 22, 2012 | Ricoh Aficio 250 Copier
Error code sc 320
Jan 06, 2011 | Ricoh Office Equipment & Supplies
Error code sc320
sc code 320 laser unit faulty polygon motor try lubricate bushing if still codeing out replace polygon
motor
Nov 11, 2010 | Ricoh Aficio MP 1600L Black and White...
Error 320
Polygonal mirror motor error.The polygon mirror motor does not reach the operating speed within 10 sec or the polygon motor remains out of the operating speed.Possible cause:defective polygon mirror motor,loose connection between the polygonal mirror motor and the BICU,defective cable between the BICU and the polygonal mirror motor or defective BICU.Turning the main power switch OFF and ON resets the SC codes if the error is caused by incorrect sensor detection.
Nov 22, 2009 | Ricoh Office Equipment & Supplies
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Oct 30, 2008 | Ricoh Aficio 250 Copier
Feb 11, 2008 | Office Equipment & Supplies
530 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
