Question about LG Televison & Video
Lg plasma 42". when the picture changes mode....normal, stretch ect. you are left with a black strip on the left side. have changed the main, power and scan boards. still the same thing. any ideas. been doing these tv since they came out but this one is puzzeling.
  • rmssls Oct 12, 2010
    done that already and checked the ribbons also. could it be a screen??
  • rmssls Oct 14, 2010
    orignial problem was dead which was resolved when the power supply was replaced. the pdp is what I was thinking a black stripe appeared on the left side but I changed the scan board first to see if it were that but it was not. Yes, I have replaced many display panels in and out of warranty.
    Thanks
    Top Expert:
  • LG Master
  • 14,553 Answers
If black strip anywhere in picture and boards replaced did not cure it---about only thing left is defective panel----black is bad, if it was a color other than that a board would cause it, I have worked on a lot of these sets under warranty---order all the boards and change and still black band top to bottom= bad PDP-----Plasma Display Panel.
Let me know if you have ever in career replaced a panel--symptom suggests a bad panel.
SD TECH
Posted on Oct 12, 2010
  • SD Tech
    SD Tech Oct 14, 2010
    The panel could have got the power board, If as I have, you have seen this before. We also do LG warranty and extended warranty, very little other than a bad panel will cause your problem.
    SD TECH
    Genius:
  • 1,622 Answers
HELLO,
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE YOU HAVE A BASIC KNOWLEDGE OF ELECTRONICS....
TAKE CARE............................
  • Todd Hill
    Todd Hill Oct 30, 2011
    so simple x board or ribbon cable conn. on x board ck solder conn on resistors on x board
Took lg plasma tv off wall when i put it back there is a fine vertical line which changes colour
HOPE THIS WILL HELP IN SOLVING THE PROBLEM.....
Aug 09, 2011 | LG 42PC3RA 42 in. HD-Ready Plasma TV
Picture size don't go to the sides about 3" black
go under the display settings you probably have it set to native mode which if it was set up for non wide screen televisions will display with black border on the left and the right. You will need to change modes if you want the black to disappear
Apr 10, 2011 | Maxent MX-42VM7 42 in. HD-Ready Plasma...
How do i get a full picture on my secnium hd tv?
Hello
To get the picture full screen come to screen aspect ratio settings.
The Screen Format feature allows you to change how the image of a 4:3 picture
is displayed on your 16:9 screen. The options are Normal, Zoom or Stretch. If
your TV receives an image with a 4:3 aspect ratio, the image can be displayed in
one of three ways:
Normal The image of a 4:3 video signal is centered with black bars on the
right and left sides of the screen
To get ito this setting mode
Enter the main menu and go to preferences select the screen format; option-2; and change the settings to get a full picture.
OK.
Feb 03, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
The left side of the LG 42" plasma TV has no
try to check the aspect ratio and input source to make sure they are correct. for the aspect ratio, make sure it is set either at 16:9 ratio or try the zoom options. if it is set at zoom, you can move the screen left to right or up or down through the zoom settings. make sure you are also using the correct cable. hope this helps
Nov 25, 2010 | LG 42PC3D 42 in. Plasma Television
I have a permanent dark/black 4.5" wide vertical line on left side of plasma TV. It seems as if it is 4:3 display mode on left side only. Any help would greatly be appreciated. I have no problem changing...
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER .
BUT IF OTHERWISE CHECK
x driver cables 10 ohm resistors have loose connections
Hope this will help...
Jun 14, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
I have a LG 42 inch plasma tv model 42pc3d....the other nite my wife was watching tv then she heard a loud pop and then noticed that the tv has sound but the picture is washed out mainly with black and...
Hello Tiangston9.
These plasma TVs have a common failure with the Ysus boards, more specific an IC that is underneath the big heatsink. The capacitors in the power supply became defective as well.
Check the link to find parts to fix your TV.
Mar 09, 2017 | LG 42PC3D 42 in. Plasma Television
42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Dec 31, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
Samsung Plasma TV
from the model number you have a 42" set,,the v_set and v_scan voltages need to be set 15vdc lower..this should take care of it,,if not then the plasma panel is bad
Nov 08, 2007 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
103 people viewed this question
Computer Repairing
Computer Repairing
