Question about Nvidia GeForce 6800 GT, (256 MB) Graphic Card
Alot of games i try to play have messed up textures...like some parts of the environment are gone and shows all the way down to lower levels, or sometimes a texture will stretch into the sky....i have the newest drivers
    Problem Solver:
  • 19 Answers
Games may autodetect and set settings to lower levels for performance, rather than visual improvement. You may need to manually adjust some settings for the game. Note that the adjusments may impact performance.
Posted on Oct 12, 2010
Cant even run wow >.> ok, I just bought a gaming
Whats your FPS in wow? (Can be seen by hovering your mouse over the Game Menu sign (the questionmark)).
Is it only low in cities with a lot of players or is it just low overall?
Nonetheless lowering the graphics will obviously help.
Just press Escape to enter the Game Menu, and then press System, and go to the Graphics tab.
You could lower the overall graphics by taking the slider down, but I believe the most important things you should do would be:
Multisampling: 1
Shadows: Low
View Distance: Fair or Low
I would also lower Texture Filtering and Texture resolution.
The thing is I am not entirely sure how the things will change when you use the slider, but I would definitely recommend just trying to slide all the way down at first. If the settings I mentioned above are higher than I posted, I would put them down as well.
Especially Shadows can be a real FPS killer.
The View Distance has no real affect and is just for the looks.
Your PC should be able to run WoW fairly well if you adjust the settings. If you wish to increase the performance without lowering the settings I'd recommend buying some more RAM though.
Anyway, tl:dr:
Press Escape to enter the menu, click System -> Graphics -> turn the slider all the way down to Low. Make sure the shadow settings is in fact on low as well. All the settings under the Effects tab can all clear up some fps if lowered/disabled.
Sep 20, 2013 | Blizzard Entertainment World of Warcraft...
When ever i click on go to race on need for speed pro street it freeze's
Most of the games that we like is the one has a better graphics and texture. To be able to run/play a specific game, you'll need to support the hardware requirements specially Graphics Adapter (Video Card). Don't get mad when your trying to play a High Graphical Texture game, and it run so slow.
This is some solution to boost your game movement -Go to Option->Video/Graphics->Set it all to low graphical quality, or disable some graphical texture settings..
I hope it will help you..
May 21, 2011 | Computers & Internet
I download the game of call of duty black ops but it's lag when i;m playing..please help me. my laptop is hp g50 notebook. thank you.
your graphics card probably isn't good enough to play that game without it lagging.you could try upgrading your ram but it might not help
Jan 10, 2011 | HP Pavillion G50-111NR Notebook
I have dell optiplex gx260 pc today i was playing game on internet suddenly my moniter turn off automaticly and again turn on automaticly and the grapics were tooooo bad to see any thing i thought its an...
First reboot your computer in safemode by powering it down, turning it back on, and pressing F8 as it boots up. This will allow you to lower your resolution back to an acceptable level so you can shutdown and reboot again normally.
As far as the automatic changes in resolution, the problem is typically with the game itself and not your pc or monitor. I have experienced this with certain games and all other games worked well before and after the problem with the specific game. The actual game you were playing when it happened would help narrow it down if you wish to post it. Hope this helps.
Dec 10, 2010 | Dell OptiPlex GX260 PC Desktop
Glitch on ati
Many of the old games use graphic textures that are not to the power of 2. This will result in missing textures, scrambled textures, black screens and more.
Unfortunately there is nothing that can be done about this aside from making yourself an old pc or resurrecting an old one just to play them.
another suggestion is to drop the resolution down to 800x600 or 1024x768 and test there to see if this solves the issue.
As graphic cards advance they don't always hold a backwards compatibility. Its just what happens.
Feb 21, 2010 | Computers & Internet
Gigabyte gt 240 Game textures not displaying correctly
might be a power problem check the wattage of your card and the output wattage of your power supply it should be at least 20% higher than your card 450 card 650 power supply
Jan 24, 2010 | Computers & Internet
I messed around with my quick setup mode and now my volume and bass is alot lower how can i fix this?
Sounds like the att is turned on or the individual speakers levels have been turned down. Get into the menu that shows the speaker levels and set them all to 0
There should be a button on the remote labled att. When the remote is in the receiver mode the button turnes it on and off, and is set sepperatly for each input (DVD, CD, TUNER, TV/SAT and so on).
So if you have a component such as a cd player that has such a hot signal that it causes distortion at any level you can drop the level of that input without affecting the others.
Jan 22, 2010 | Pioneer VSX-D508
My copy of Links Awakening is messed up bad. The
You cannot fix it if you used to many gameshark cheats on it or if it is the internal battery.
Nov 26, 2009 | Nintendo Legend of Zelda: Link's Awakening
Missing texture message appears when it loads
follow my steps
first solution: go to run-->dxdiag--->select hardware acceleration to standard and save it
or
second solution: right click in the desktop and select the properties and select the setting--> advanced and select hardware acceleration to medium and check the display properties and check the texture level
Feb 12, 2009 | EA Sports Cricket 07 for Windows
Nvidia GeForce 6800 GT, (256 MB) Graphic Card Logo
67 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
