Question about Pool & Spa
SOURCE: Baracuda G3 zodiac Clings to bottom or sides moving slowly
here is a link to the Technical Support at Baracuda. this should be able to solve your problems. initially sounds like maybe too much suction.
Posted on Feb 26, 2009
SOURCE: Zodiac G4 will not move
Verify nothing is stuck inside the vacuum. Try adjusting your intake valves to reduce flow from your skimmer(s) and increase flow from the vacuum. Also, how old is the diaphragm inside the vacuum? Inspect it for rips and tears. Also, check the flex hose for rips and tears as well.
Posted on Aug 25, 2009
SOURCE: Barracuda Zodiac G3 is not pulsating. It's got
either some debris is caught in the diaphragm or it's deformed enough to render it inoperable. Unthread the nut just above the handle and pull it apart, then push the white tube downward until it comes out of the bottom of the unit. Inspect the diaphragm to see it there is any debris in it or if it is deformed. Usually the diaphragm has a uniform opening, if the gap is wide, it will not function. The most common problem is that the diaphragm needs replaced. Hope this helps.
Posted on Nov 19, 2009
SOURCE: barracuda not bouncing or moving to clean pool
Check suction at cleaner. Could be broken hose, bad or dirty impeller, incorrectly set valves, dirty filter, clogged line and probably a bunch more things.
Posted on Jan 14, 2010
SOURCE: Hi, we have a Zodiac
With these pool cleaners, getting stuck in one spot is most likely the result of a waterflow problem. Check your water flow valve and make sure that it is adjusted correctly. make sure that you don't have any blockage that would prevent movement and cause the cleaner to stick in one place. This might seem like common sense, but make sure that you have enough hose to reach the entire pool. Many times, when this occurs, the cleaner cannot reach one part of the pool. make sure that your hose balance is correct also.
Posted on Oct 26, 2010
Aug 23, 2014 | Zodiac Baracuda G3 Automatic In Ground...
Mar 17, 2013 | Zodiac Baracuda Mx8 - In Ground Suction...
Jan 29, 2011 | Zodiac Baracuda Zippy Pool Cleaner
Dec 29, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Nov 22, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Oct 30, 2010 | Zodiac Baracuda Zippy Pool Cleaner
Jan 10, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Dec 17, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
May 29, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Feb 25, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
316 people viewed this question
