Question about Radio Communications
No sound on cb radio
I have a TRC 446. I get no sound from the radio while in the cb mode. When I turn it to the weather channels I have sound. I have no idea what happend.It was working fine until the other day.
  • 47 Answers
Do you get any other sound from the speaker?
check squelch settings
does external speaker work?
If yes - internal speaker is bad
If No - either the Audio Amp chip is bad or the external speaker socket is bad
Posted on Nov 14, 2008
Trc 446
with this radio,I would probably go and buy another . It will be cheaper than having someone fix it.give more information about what its doing or not doing and maybe some one will give you the help you need but I would buy a better radio.
Sep 03, 2014 | Radio Shack 40 Channel Cb Radio Model...
My trc 446 wont recevie ecept for weather
check your mic connections ,make sure there are no broken wires.
Dec 24, 2013 | Galaxy Radios DX-99V 40-Channels Base CB...
Need mic wiring diagram for trc-446
you may have to order one from radio shack because the wireing diagram is for that radio and mic only . You cannot use another mic on that radio , only the one that comes with it . If you are patient enough and have another mic with the same controls you could wire it up. it has to be ( I think a 6 pin ) ???
Nov 10, 2013 | Radio Shack 40 Channel Cb Radio Model...
Cb radio trc446 rewiring microphone color coding
if you pulled it completely out you may have a problem . Trial and error is all I can tell you.Get a volt meter and check the mic pins on the radio . Ground one lead and touch each pin for ohms the first one to make noise is the ground. then touch the ground with one lead and touch the next pin and the next . now if there is any left over wire on the plug you can rewire it , then go from there.
Mar 25, 2013 | Radio Shack 40 Channel Cb Radio Model...
Realistic trc 443 cb quits transmitting and recieving
Sounds like the weather alert system is getting activated.
Jul 26, 2010 | Uniden PC78ELITE 40-Channels Base CB Radio
Cobra 75 wx st everything seems to work eccept receiving signal meter will spike on trx and it seems to receive but no sound there is sound in wx mode
WX is for weather. If you put it on WX, and you do not hear anything, then you need to change the weather station it is on. in wx mode, you change weather channels by pressing channel up and down. To communicate with 2 way, press the cb/wx button so it is on CB mode.
Sep 28, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
CB RADIO TRC 446 WILL NOT RECEIVE
IF YOU CANT RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Jan 29, 2009 | Galaxy Radios DX-99V 40-Channels Base CB...
Radio Communications Logo
506 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
