Question about Sony Playstation 3 (PS3) Console
When i entered the cd to my ps3 it wont eject anymore and it does'nt appear in the menu???
Is my ps3 is not working anymore?
    Scholar:
  • 65 Answers
If the PLAYSTATION 3 does not recognize the disc: To PS3 Support Site
  • Remove the disc and reinsert it.
  • If the disc has a label, insert it with the label side up.
  • Check whether the disc is scratched or dirty. If dirty, wipe it gently with a soft cloth.
  • Make sure the disc has not been exposed to high temperatures, high humidity or direct sunlight. When discs will not be used for an extended period of time, store them in their cases. Stacking uncased discs or storing them at an angle can cause them to warp.
  • DVD-R/DVD-RW/DVD+R/DVD+RW discs that have not been finalized cannot be played.
  • When outputting DVD content or PLAYSTATION 3 format software in SD resolution, only discs recorded in the NTSC standard can be played.
If You need to Contact Customer Service Call Sony at
1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Good Luck,
-Rel
Posted on Jun 01, 2008
Ok i have ps3 when i turn my ps3 on the blue and green light is on but when i go to game menu the cd doesnt appear.. and if press button for eject it alost not working
there might be som minor error with the ps3 and this king of errors can easily solved by this site whish has the complete repair guide for ps3 ...try it...
Dec 03, 2010 | Sony Playstation 3 (PS3) Console
My ps3 froze the other day . So i waited but it didnt unfreeze . so i tried to press the middle button on my controller and the menu did not pop up . so i tried to reset it &&the green light...
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
May 10, 2010 | Sony Playstation 3 (PS3) Console
The container that hold my dvd disk wont come out when I press the open button on my apple computer?
It may be stuck so what you can try are one of these options:
Option# 1
* Shutdown your iMac G4
* Before you turn on your iMac, hold down your mouse button(s).
* Turn your iMac on still holding the mouse button(s) down.
* You will need to keep holding, until your disc ejects as your iMac starts up. That should do it.
Option# 2
If it does not, try using the Terminal utility to attempt to eject the disc.
* Click anywhere on the blank space of your desktop
and then you should see Finder appear near the Apple menu icon located in the upper left corner of your screen.
* Now from the Finder menu, select Go > Utilities.
* Within the Utilities folder. locate the Terminal application and launch it.
* When the screen prompt appears, type:
drutil tray eject
Option# 3
If that does not work, you can also try ejecting the cd using Open Firmware:
* Restart your Mac and hold these keys:
* Hold Command, Option, O and F keys while booting up.
* Now type: eject cd
To exit the open firmware screen type: mac-boot
One of these 3 methods should eject your disc.
If not, you may have a genuinely stuck CD in your drive and may need to take your iMac in to your local Apple retail store Genius bar or local Apple-authorized service center to have it safely and correctly removed.
Honestly, however, I have this same type of iMacG4- you will probably have the cd out by Option # 2 :)
Regards,
-Mactechtrainer
Jan 04, 2010 | Apple iMac G4 Desktop
My ps3 disk tray wont open
Try this first: Hold down the eject button for 10 - 15 seconds. this is supposed to work as a manual eject for the PS3. If that does not work, Try Reformatting the PS3 hard drive, youll find the option under settings in the PS3 menu
Don't 4get 2 backup ur stuff first!
Oct 17, 2009 | Sony Playstation 3 (PS3) Console
Not able to gat to the menu
turn on ps3 leave on stand by (red light), hold eject button and power button until you hear beeps and a message appears. connect controller and press ps button. system restore screen should appear, select restart system and from there it should restore everything back to normal
Aug 26, 2009 | Sony Playstation 3 (PS3) Console
97 Jetta. Radio works but 6 cd changer not getting power anymore
Look in your owners manual for the fuse number and it's location.
Jul 28, 2017 | 1998 Volkswagen Jetta
My ps3 won't play ps3 games anymore. I was playing lego batman and then the game froze. so I turned off the ps3. I turned it on again and the game icon didn't show up anymore. I tried several games and...
I had the same issue. I had to send it to PSR Repairs to have it checked out. They ended up replacing the hard drive & the laser lens. According to them, both those components contributed to the freezing up & inability to turn back on. Before I sent it in, I was able to get it to turn back on by holding down both the power button & eject button simultainiously. Lie it beep once, then double beep... Once you hear the double beep, release both buttons. A menu will come up giving you 6 options. Try option 3 first! you wont lose any saved items with this option. If that doesn't work, you will need to use option 6. This will delete ALL of your saved items, but there's a chance that you may not have to have your console repaired. You can retrieve trophies, games & demos from the PlayStation Store. Good luck! If I can be of further help, comment me back under this heading!
May 12, 2009 | Sony Playstation 3 (PS3) Console
Disk will not go into PS3 appears to be blocked
Press and hold the eject button for around 15 seconds, this resets the cd drive and will fix your problems. Hope this helps
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Help cd stuck in my ps3 console
hold in ps button on controller, switch off system and restart or quit the game and go to the ps3 main menue, eject it from the menu by going to options on the cd, dont do it manually especially with a ps3 game, it only really works with a dvd.
Dec 30, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
