Question about RCA RC128 Car CD/ MP3 Player
I have a rca radio (rc188m) for my boat the disp.comes on when i turn it on it stays on a few minutes and goes off . the display says disp. off how can i turn it on to say disp. on ? thanks...jc
Shuttle83
  • 1139 Answers
SOURCE: RCA Big Screen Turns off
This is a shutdown circuit problem, I would suggest that you send it to atv shop, or find a shop on FixYa.com to look at this for you. I have fixed problems like this in my shop, but I always require the customer for pay a schematic and a exploratory fee prior to me starting the job, other shops may or may not do this, so shop around first.
Posted on Sep 08, 2007
800pctechs
  • 39 Answers
SOURCE: my rca 52 inch hdtv turns itself off after a few minutes
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
Posted on Oct 02, 2008
  • 3 Answers
SOURCE: RCA Rear Projection TV goes black after a few minutes.
Check the lamp to see if it needs replaced.
Posted on Dec 02, 2008
ladywinn
  • 5138 Answers
SOURCE: my rca tv picture goes off after a few minutes but
Resolder all pinns on FBT flyback transfomer and ck capacitors cp150 2200uf 16v if it is swollen or puffed up on top it is bad replace it and 2 more cp114 cp 120 220uf 35v.
Posted on Sep 20, 2009
  • 8457 Answers
SOURCE: rca truflat 13
Ur video board that connected to the CRT(tv tube)long neck.It needed resolders the board it have cold solders.U know how to solders, resolders the ssockets pins that the CRT video board connected to.
Posted on Nov 10, 2009
Low tire pressure light wont go out
The Low Tire Pressure Indicator must be reset using the Radio. This can only be performed if you have the factory radio installed in the vehicle. This vehicle does not come with an active tire pressure management system, and as such, this light must be reset manually.
1.) Turn Radio Off 2.) Hold down disp button for 10 seconds 3.) Setup Menu should display 4.) Scroll through menu to view "Tire Pressure" (use seek buttons) 5.) Select the Tire Pressure option (Press Radio Button 1) 6.) Reset should be displayed on screen (Press disp button) 7.) Tire Pressure Light should reset
Nov 29, 2010 | 2000 Chevrolet Impala
Set time car radio/cd Panasonic CQ-C13367
First of all, go to service.us.panasonic.com/operman to get the manual for your unit.
With the unit turned on and the clock displayed, pres disp for more than two seconds. The hours will blink... press < or > to adjust hour. Press disp again, the minutes will blink... press < or > to adjust minutes. Lastly, press disp to store the correct time. Good Luck!!!
Nov 09, 2010 | Panasonic Car radio CD CQ-C1110GN CD...
Resetting oil life sensor
USING THE RADIO:
Follow this procedure to reset the GM Oil Life System.
Turn the ignition to ACC OR ON, with the radio off.
Press and hold the TUNE DISP button on the radio for at least five seconds until SETTINGS is displayed.
Press the SEEK PTYPE or the SEEK PSCAN up or down arrow to scroll through the main menu.
Scroll until OIL LIFE appears on the display.
Press the 1 PREV or 2 NEXT button to enter the submenu. RESET will be displayed.
Press the TUNE DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second.
Once the message has been reset, scroll until EXIT appears on the display.
Press the TUNE DISP button to exit programming. A chime will be heard to verify the exit.
USING THE ACCELERATOR PEDAL:
Turn the ignition to ON, with the engine off.
Fully press and release the accelerator pedal three times within five seconds.
If the CHANGE ENGINE OIL message flashes, the system is reset. However, if it stays on , it did not reset. Repeat the procedure.
Source(s):GM Service Manual
Jul 03, 2010 | 2006 Chevrolet Impala
I have a rca hd56w66, my screen shuts off but the audio still stays on. For a few days, it started fading to orange and then to green and then out to black. After about a minute, the picture would come...
Sounds like you lost the power supply to guns, now this doen't mean you have to go looking for it, you will need a repair person to fix it. Word of advise, if you haven't had one of these fixed before it can range in upwards of 600.00 or more to fix now days.
Oct 09, 2009 | RCA HD56W66 56" HDTV
Low Tire Pressure Alert won't Clear
2 ways disconnect the battery for about 5 minutes or hook up an obd II and erase the codes
Mar 22, 2009 | 2002 Chevrolet Monte Carlo
Eclipse 55430 User's Manual
Here's how to set the clock on the Eclipse 55430:
1. Press the [DISP] button repeatedly to switch to the clock adjustment mode.
2. To adjust the hour, press either button [1] or [2] while holding the [DISP] button down.
3. To adjust the minutes, press either button [3] or [4] while holding the [DISP] button down.
Hope this helps!
Aug 23, 2008 | RCA Pie Pio/P Rca Adapter P Bus Mcd To Aux...
Setting clock
1.Press and hold the (BND) button, then press the (DISP) button to display the clock display.
2.Press and hold the (BND) button, then press the (DISP) button for about 2 seconds (the number will flash).
3.Press the << button to toggle between hour and minute selections. Then turn the ROTARY(volume) knob to increase hour/minutes.
4.Press the (BND) button, then the clock is set!
Kurz
Apr 07, 2008 | Clarion DB245 CD Player
How do you set the clock on the panasonic cq-c1121u cd radio.
1 Turn the ignition switch until
the accessory indicator
lights.
2 Press [SRC] (PWR: Power).
3 Press [DISP] (CLOCK).
4 Hold down [DISP] (CLOCK) for more than
2 seconds.
5 Adjust the hour.
[[]: sets the hour ahead.
[]]: sets the hour back.
6 Press [DISP] (CLOCK).
7 Adjust the minute.
[[]: sets the minute ahead.
[]]: sets the minute back.
8 Press [DISP] (CLOCK).
Notes:
¡ "AdJ" is displayed before adjusting the clock.
¡ Hold down []] or [[] to change numbers rapidly.
power off displayPower Off
Press [DISP] (Display) to change the display.
Mar 10, 2008 | Audio Players & Recorders
RCA RC128 Car CD/ MP3 Player Logo
Top RCA Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jeff Turcotte
Jeff Turcotte
L Pfaff
L Pfaff
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
