Hey, this is Jeremy with Crucial Vacuum,
I am sorry to hear that you are having problems with your vacuum Kylie. I believe the issue may be a result of the belt or brush not being on perfectly. If either of them are off slightly it can cause your vacuum to potentially shoot out dust.
If the problem is related to suction, I have provided you with some steps below to fix the issue.
1. Check the canister to see if it is full. If so, simply empty it into your waste receptacle and make sure nothing is blocking the hole where dust and debris enters the canister.
2. Check to see if the hose is clogged. To do so, take off the canister and look down the tube where debris enters from. If you see any obstructions try to use a pair of tweezers or something else to dislodge the obstruction.
3. The roller brush may be clogged. To check, turn your vacuum on its side and look at the brush. Make sure your vacuum is off when doing so. Sift through the brush making sure nothing is lodged in the brush.
4. Your filter may be too dirty. You will either need to clean your filter or replace it with a new one depending on how old it is. To clean it push the purple tab at the top of your vacuum and remove the handle. Then, remove the filter and determine if it can be salvaged.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
