Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
I am changing the belt on a oil less 33 Gallon vertical 1.6 hp Craftsman Compressor and want to know if the bolt that holds the piston rod on is left hand or right hand threads?
    Scholar:
  • 146 Answers
This is standard thread, right to tighten and left to loosen.
Make sure to put a small amout of loctite on the threads when you put it back together.
Posted on Oct 13, 2010
Testimonial: "Thanks so much. Excellent response!!"
Air compressor makes loud knocking nois when running
remove shroud and see if fan is broken but may be piston is shot
Apr 10, 2013 | Craftsman 33 gal Air Compressor 6 hp...
I have a 6hp 33 gal aircomp i builds up to 100 should go to 250 wont shut off because not up to press can you help
Sounds to me likt you have a bad motor, or compressor. The compressor rings might be leaking by only holding 100 psi.
Aug 10, 2012 | Craftsman 33 Gallon Vertical Portable Air...
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Sources of noise from craftsman oil free compressors (could be Made by Campbell Hausfeld or Porter Cable) include loose fan, failing bearing/s on the piston rod and housing, failing seal ring on piston, air filter intake and loose motor mounts. With the housing cover off, check the fan blade for cracks or loose screw. Turn motor by hand till the piston is at top of stroke. Examine the cylinder for scratches close to top. If scratched, air is leaking past vinyl ring making noise and causing longer fill time. If everything looks ok, suspect noise coming from bearings. Hard to tell if bearings are failing by looking at them. I have seen many failures of the piston bearing on the crank (fairly easy to change, I use alternator bearing from auto parts ) , however, the bearing in the housing just behind the crank bearing is much harder to replacable. Good luck with your fix-it project.
Jun 11, 2012 | Craftsman Air Tools & Compressors
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
I have a Craftsman 33 gallon vertical air compressor with reduced noise motor. After not using it for a couple days, it won't start. There is power to the motor. Turned the pulley with power on in both...
The HP is to low for the 33 gallan copasity of the tank 6 hp is not enough If you are trying to run things that draw a large CFM . The disgin of the mechine is incorrect sorry its one mans oppoin the thing can't do what it says it can
Apr 07, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Broken connecting rod
i broke the rod in my air compressor and cant find a place to buy a new one it is a pro source
Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
173 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
