Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Husq 455 rancher chain saw. the chain locking spring in the cover is in the lock position and will not mount on the saw. how do i release the spring tension?
    Problem Solver:
  • 4 Answers
You should be able to release it with a flat screwdriver. you should see something that looks like a wheel where the chain brake locks to the brake handle when you put the cover back on. you should be able to twist that wheel and unlock it that way.
Posted on Oct 12, 2010
Will start but will not stay running
The 455 was very prone to blocking the fuel tank vent, as a test, when the saw starts to die release the fuel cap, if the saw picks back up and runs normally it is a breather issue, the breather is pressed into the crankcase under the starter cover.
Feb 26, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
HUSQVARNA 455 RANCHER - HOW TO UNLOCK CHAIN BRAKE WHEN COVER IS OFF THE SAW?
Go to http://www.milacalawn.com/parts.asp and look for the bolt that hold the brake.usually the bolt is located in the chain plate that has a large groove in order to adjust the chain.
Oct 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Cutting a log with 455 rancher chain locked up took cover off replaced chain ,chain spins with cover off put cover on chain is locked up again husqvarna
It sounds like the chain is too tight. Loosen up the tension on the chain by turning the tensioning screw located on the end of the saw where the bar goes out.
Feb 26, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Cutting with 455 rancher chain locked up took cover off ,replaced chain and put cover on still locked up
Husqvarna - IPL, 455 Rancher/ 460, 2006-02, Chain Saw (example - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601076.pdf
See Detail A, pn 503 89 08-02. You can use a Crescent Wrench on one of the ears (left end) to reset it. With the cover positioned with pn 503 89 08-02 in the upper left rotate it CW until it nests, to reset it.
This works quite well:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
You can download the IPL for you saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I will wager you will NEVER again remove the cover with the brake set. Me either! Good Luck. HTH
Lou
Feb 25, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
How do I release the brake spring with the cover off?
I had this problem once and it was very tough for me to fix. Maybe there's a tool that makes it easier but I struggled with vise grips and pliers for our until I finally got it flipped back. I had to take off the plastic cover that encloses the spring to do it. It's definitely easier for two people.
Sep 09, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Have a 455 rancher and spring came out of chain brake mechanism
HI.I DON'T KNOW WHERE YOU LIVE BUT I HAVE 2 OR 3 OF THEM. THE BEST THING TO DO GO TO THE PHONE BOOK AND START CALLING REPAIR SHOPS. I HOPE THIS HELPS YOY. JIMBO
Aug 09, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
CHAINSAW BRAKE LOCKED ON HUSQVARNA 455 RANCHER HELP PLEASE?
I used applman08's solution. A few pointers:
0. This problem occurs when you take off the side cover while the brake is set. So after you fix this, don't do that again.
1. When removing the clutch, place the screwdriver in the notch next to where it says "off" and tilt the screwdriver down so that when you strike it you are applying a clockwise shock force that is almost horizontal (assuming your 455 is on its side).
2. DO NOT remove the spring! There is a plastic housing that basically holds the brake mechanism in place (secured by 4 screws). If you take that apart, and then take out the spring, you will be learning how the brake works and spending some time compressing that spring and getting it back in. You'll have to come up with something clever to get the spring in depending on tools available.
3. Going back to 1. - get that clutch off, put the side cover back on, getting that brake lever lined up with the very-difficult-to-grab three-toothed mechanism for engaging the spring. Tighten down the side cover, or hold it snug with one hand while you lever the brake handle with the other. You will hear a satisfying snap as the braking mechanism (with the spring I told you not to mess with) resets.
Note: You can probably reset the braking mechanism by manually turning that three toothed gizmo but it's really hard to grab and the brake handle fits it perfectly. The key is you've got to turn that about 60 degrees.
Good luck, this was an annoying problem.
Nov 01, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
436 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
