Question about Bosch HBL 455 Stainless Steel Electric Double Oven
Bosch oven F03 error message
I am seeing F03 error message in my Bosch oven.
what is the problem on this?
What is error code f03 and how do i fix it
F3 or F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
May 19, 2015 | Hotpoint Ovens
Ariston wall oven error code f53 f03
I managed to resolve that problem. When you have BOTH F53 and F03 error codes, it's not a sensor fault (although F03 is the big cavity sensor and F53 is the top one)... it's a faulty capacitor trouble. On the main board there are 4 electrolytic capacitors, just replace all of them and you're ok again. It's quite simple and very cheap. :-)
Nov 26, 2013 | Ariston Technologies Ovens
After a lightning storm my bosch single 30" wall oven displayed an F03 err. I turned the power supply off at the breaker for one minute as directed by the oven's manual. This action did not...
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
Sep 07, 2017 | Bosch HBL 5036 Electric Single Oven
Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
F03 Displays
I bought a new oven found this one way to complex anyway. Afterall i just want to cook in it.
Regards
Ken Mc
Sep 14, 2009 | Whirlpool RBS305PDS Electric Single Oven
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 | Ovens
Whirlpool range gas model GS445LEMS
i have the same problem oven comes on but goes back off. help
Jun 26, 2008 | Whirlpool SB160PEE Gas Single Oven
Error code F03
although i don tknow what model your talking about all the F3 codes in ovens is pointing toward bad oven sensor, replace oven sensor
Mar 16, 2008 | Ovens
Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Sep 28, 2007 | Ovens
Bosch HBL 455 Stainless Steel Electric Double Oven Logo
336 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
