Question about Sony Handycam DCR-TRV140 Digital Camcorder
Sony handycam is flashing a code C3123 - Sony Handycam DCR-TRV140 Digital Camcorder
    Genius:
  • 1,812 Answers
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Posted on Oct 12, 2010
Hi there I am getting code c31-23 can you please
This is one of the most common problems on sony camcorders. It is caused by the loosening or loss of the rubber roller inside the tape drive mechanism. Try tapping the top of the cam when the tape is inside. If this doesnt work, open the tape deck and look inside to see if you can spot a single rubber roller inside. If not, then the roller has worked itself loose or gone AWOL missing..:(( However, fear not...the solution for this is to go to an office supply store and obtain one of those compressed air cans used for dusting off keyboards and such. Amazingly, the plastic tip on the compressed air can (where the air comes out) can be used as a replacement for this rubber roller. It fits the metal spindle that formerly held the roller perfectly and allows the cam to function without the rubber roller and without the dreaded C31:23 "your camera is dead and useless and will no longer function" evil Sony message... Check out this link for a discussion of this problem: http://wvstephens.blogspot.com/2008/05/sony-handycam-c3123-3123-error-easy-fix.html
Jul 28, 2010 | Sony Handycam DCR-TRV140E Digital...
Hi, I have a sony handycam dcr-sr32 camcorder fault code E61:10
Either focus motor or zoom motor not working so that error code E61:10 fashing
Mar 10, 2010 | Sony Handycam DCR-SR42 Camcorder
My sony digital handycam flashes C:31:42
C:31:42 indicates that you having a problem with capstan motor. It has to be replaced.
Nov 05, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
It keeps coming up to eject the tape and reads c3123
The camcorder has to have it's belts cleaned or replaced. This is a highly intricate proceedure and should be done proffessionally.Thank you, Dana
Oct 30, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony Camcorder DCR TRV50 error code c 31:23....do you know how to solve this problem? It had been serviced already..& here we are again. Seem to be a problem with this model. Help!!
This seems to be related to the black rubber roller inside the camera, either falling off or losing the bushing and getting too loose. It's an easy fix once you figure out where to look I just fixed this problem by referring to this link:
His solution says to use a compressed air straw to make a new bushing. This was too small for me, but I looked around and found a little extension straw that was the right diameter. This seems to be a common problem with a lot of Sony camcorders. Google Sony C31:23 for more info.
Oct 09, 2009 | Canon MV630i Mini DV Digital Camcorder
Error C:31:23 on Sony trv27
Jun 12, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
Not able find the exact one. Adobe flash player is not suiting this handycam
    Please install Acrobate reader on you pc that has also FLASH PLAYER  or from below link you cam easily cohice any flash player which fulfill your requirment.The link is given below :
www.download.com
Thanks for using fixya.
May 10, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Flashing error message C:31:23
Hi Jazzy,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Jan 09, 2009 | Sony Handycam DCR-TRV240E Digital...
Turn on and flashes c3123
I had the same problem, but then I found this site: http://www.pechorin.com/m/2004/11/16/FIX_for_Self_Diagnosis_C3122-226151.html
It sounds crazy, but just turn off the camera give it one or two firm smacks and then turn it back on.
Dec 12, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Dcr trv245e
Error code C31:23 indicates a failure with the tape drive mechanism. Most likely a sensor has failed and must be replaced. I can repair this for a flat rate of $125.00 including parts. Contact me if I can be of further assistance.
Thanks,Frank
fselman@comcast.net
Nov 23, 2008 | Sony Handycam CCD-TR818 Camcorder
Sony Handycam DCR-TRV140 Digital Camcorder Logo
309 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
