Question about Norelco Arcitec Electric Shaver - Gray/Black
Can not get blades out of head to clean blades & foils
  • Norelco Master
  • 1,610 Answers
The blades can not be removed from the head assembly on Arcitec models. This is the way they were designed from the manufacturer.
The only way to clean them is to rinse them with HOT water or soak them in mild liquid like rubbing alcohol.
If that doesn'tget them clean, you will need to replace them. You will fin replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Posted on Oct 13, 2010
I have braun shaver 190s1 fully charged but the blades are not rotating for me to shave
One or more of the shaving heads is stuck on the blade foil. The latter is very delicate and wears. If there is a break in the foil often a metal shard intrudes into the path of the moving blades and it gets stuck. Remove the foil and turn on shaver - if it runs it is the foil that has to be replaced.
Nov 22, 2013 | Braun Health & Beauty
Trimmer of my Panasonic EX3833S is not working
panasonic es3833 replacement foil and blades
panasonic WES9979P combo set for electric shaver panasonic es3833 replacement heads.
panasonic WES9941P outer foil for electric shaver panasonic es3833 replacement parts.
panasonic es3833 replacement blades
panasonic WES9942P replacement blade for electric shaver part panasonic es3833 replacement parts.
Aug 25, 2013 | Panasonic ES3833 Electric Shaver
How can I clean my braun washable series 3 (330) shaver. better. I can take it apart so far but just cant get under the blades
This model uses a 'shaving cassette'. The blades can not be removed from the foil assembly. Braun's instruction is to simply rense the shaving head under hot running tap water. Unfortunately, this does not work very well over time due to the poor design of these parts. Once they become clogged up it is usually necessary to replace the cartridge.
If replacement is needed you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jul 27, 2011 | Health & Beauty
I dropped my 8985 braun and it will no longer shave with the foil head on. It does work if you remove the foil. Did I loose a part?
You probably dented the foil head enough to stop the vibratory action of the blades, thus the working when the foil is removed. Braun has a replacement foil and blade kit sold at Walmart.
Dec 04, 2010 | Braun 8585 Electric Shaver
Panasonic shaver Model ES8068 Linear pulls facial hair rather than cut
panasonic es8068 replacement foil and blades is panasonic WES9079P replacement outer foil and inner blades.
panasonic es8068 replacement blades is panasonic WES9070P inner blades.
Sep 02, 2010 | Panasonic Linear ES 8068 N
Where should i can buy ms5100 shaver blades
remington SP-96 replacement screen foil and cutter heads for electric shaver remington ms5100 blades replacement parts.
Mar 17, 2010 | Remington MS-5100 Electric Shaver
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
Norelco Arcitec Electric Shaver - Gray/Black Logo
225 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
