Question about Mitsubishi WD-57734 57" HDTV
Lamp light begins blinking as soon as unit is plugged in. Replaced lamp and same result.
    Sergeant:
  • 171 Answers
Have you reset your TV set all ready, there is a botton in front of your TV that you can push with a pen or a pencil. hold it down for 10-15 seconds and unplug the TV for a hour then plug it back in, if it still does the same thing then you have a problem with your ballast board and you need to replace that part here is the service manual. for your set check page16 it will show you how to replace this board
http://www.audiolabga.com/pdf/V36-V37-V38_Service_Manual.pdf
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!!
Posted on Oct 12, 2010
When all three lights are blinking what do I do?
If the unit uses a ballast for the lamp, it could be that it needs replacement of the ballast.
Aug 25, 2017 | Office Equipment & Supplies
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
I replaced lamp on mitisubishi WD-60735. The Lamp light is still blinking yellow, the timer light lit up green, but lamp still blinking yellow
Are you sure you installed the lamp properly and put the door back so the interlock switch is functioning. Sometimes installing the lamp will get slightly displaced and is not plugged up properly and will indicate a lamp blinking light.
May 18, 2011 | Mitsubishi WD-60735 Projection Television
Sony Bravia KDL46XBR-LCD. No picture but sound. Trouble shooting light blinks 5 times in cycles. What does it mean.
If your television blinks 5 times or for a count of times, it simply is indicating that there is a problem inside the unit.
The problem applying to this situation is a faulty lamp. The lamp is bad and simply need to be replaced.
As soon as you replace the lamp, the television will be in good condition once again.
Take care and good luck
Nov 06, 2010 | Sony KDF-E55A20 55 in. LCD Television
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
KDF-60xs955 Sony WEGA. TV has no picture, no sound; green light blinks for a while then stays on. NO RED BLINKING LIGHTS. Replaced the bulb with no change in result. I would think it is NOT the...
Hi,did you close the door cover?Make sure itsproperly shut other wise it won't tv light up. Reset the lamp
timer? you can do this by unpluging the set for 5 min
and plug it back(works for most sets). Was the fan
running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on
and the red light will blink.Also did you get the original Philips lamp if you got a generic that
could be your problem.God Bless you!
Nov 25, 2009 | Televison & Video
New lamp won't light
I am having the same problem now. I am currently trying to reset the timer...but have yet to successfully. But I do think this is the solution.
Jun 10, 2009 | Sharp DT-100 Multimedia Projector
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Panasonic PT-AE900U Projector Lamp stops working (intermittent)
Could be a heat sensor, fan bearing issue..have you listened to the fan speed etc, But I think more along the lines of the lamp needs replacing..each time you resit it is thinking ah a new lamp and then realises hey someone is fooling me and shuts down...this scenario is doing you a favour as typically if it blew and shattered the glass it will inevitablly scratch the mirror and lcd block... and if it does that you might as well toss it in the rubbish or sell on ebay for $50 ..
Regards Kevin Andreassend, ICE AV Technology Ltd www.iceav.co.nz iceavtech@gmail.com
Apr 03, 2009 | Panasonic PT-LB10VU Multimedia Projector
Green Timer lights blinks for about 10 sec. Then Lamp light, then nothing
Definitely sounds like a power supply problem. Check with your local TV repair/service center about getting it repaired or replaced.
Dec 19, 2007 | Mitsubishi WD62627 62" HDTV
Mitsubishi WD-57734 57" HDTV Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
