We have ca-5130d no power was getting through so i checked fuse which is hot and black - has it blown
  • 44 Answers
Possibly. Change it and try again. If it blows again there is likely a problem with the unit.
Posted on Oct 12, 2010
How do I open a JVC CA-MXJ50 to check for blown fuse have no power
You should go to www.reliable-store.com they have got books on every vehicle and also how to service/repair it,
service/repair/owner's/maintenance manual with
parts info, fuse box, gear box, torque specs,coiling, wiring diagrams, electrical diagrams, fuse diagrams, error codes, etc everything
Worth it
Mar 15, 2018 | Cars & Trucks
I hooked my battery backwards now my 95 GMC won't run no fuel no spark what's can it be
Bad DOG! Break out the checkbook, you may have blown the computer. Need to start there. Not sure if there is reverse polarity diode protection or not. Have it checked. Even at a scrap yard they won't be cheap.
Apr 15, 2014 | Cars & Trucks
No power to windows, radio, dash
I would start by checking if the under dash fuse panel is getting power to all the fuses. A few will be hot at all times (like the brake light fuse, horn fuse), but with key on, all fuses in the fuse panel should have power available to them.
Use a test light, clip the ground clip to a metal bracket, and use the test light probe to touch the fuses at the ends-the little indents on top of fuse is open to the metal strip in the fuse. When the probe touches that strip, the test light should light, meaning power is getting to the fuses. No light? Maybe not grounded good-keep trying until you get a light when touching the fuses through that little **** at top of fuse. When you have a good ground, check all fuses. With key on, all fuses should have power-now you can check the radio fuse and dash fuse.
You can do this also to check for a blown fuse. Even a blown fuse will light the tester on one end of fuse. A good fuse will light tester on both ends of fuse. A blown fuse will only light tester on one end. You can check fuses this way without pulling the fuse out to inspect.
If no power to the fuse panel or to part of the panel, look for a bad fusible link or maxi fuse that distributes power to the fuse panel. There may also be a relay (ignition relay) that the key switch turns on to send power to the fuses that are hot in accessory or run.
Sep 30, 2013 | 2001 Toyota Celica
I try to turn the tv on but there is no power.
check the incoming power with a tester and if ok then check the plug fuse and if burnt replace and if ok proceed to open the tv cover and check the cable continuityand check the fuse in the power supply region if blown, check other components inthe power supply area and replace the faulty ones if any then open the fuse in the power supply and connect a 100w test lamp to see if there is a short circuit. if the bulb lights up and gets dim gradually you ca now remove the lamp and put backthe fuse and test again
however, your tv problem could be solved by simply replacing a burnt fuse but its always advisable to verify the cause of the blown fuse
Sep 21, 2011 | Sanyo Televison & Video
Dryer runs but does not get hot to dry clothes
Hello there:
There are a couple of things to check if the dryer does not heat properly
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Feb 27, 2010 | Dryers
Roper model rex5634kq1----won't get hot---already removed &ck'd heating element & attached part (thermostat?)--they're both ok--what else could it be?
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Dryers
Stopped Working!
check the switch or thermal fuse, if it has.
Aug 29, 2009 | Black & Decker TRO603 Toast-R-Oven Toaster...
Black & Decker KX2000K Heatgun Kit 2000w cuts pout after minimal usage is it fuse blown ??
no its not the fuse in the plug but it could be the internal turmal fuse triping out on you,,,if its getting to hot this thurmal fuse will tip out keep intake vents clean and clear when using the hot air gun,,
Aug 27, 2009 | Black & Decker Black and Decker 1500w...
No Power
hi,
Did you try replacin the fuse.It might have blown.
Jul 03, 2008 | Sharp R-930AK Convection/Microwave Oven
18 people viewed this question
 Grubhead
Grubhead
