Question about Ahead Software Nero 7 Essentials Suite Full Version OEM
I get the error : internal error: couldnot open the second advanced file dialog Looks, like you didnt register some dlls nero 7 error nero 8 express when i tryed burning an audio CD with nero 7... Could the cause of this b the nero 8 express that is installed on my system ?
2 Suggested Answers
SOURCE: internal error : couldn't open the second advanced
I can not remove Nero 7 essentials full OEM Suite from my computer. It keeps saying that it has an internal error. The window I am running is Windows 7 Home Premium.
Posted on Aug 29, 2010
Nero looks like you didn't register some dlls
Please post the version of your Nero. What is your operating system? It seems you experienced incompatibility problem.
Mar 03, 2014 | Computers & Internet
Unable to copy music to cd by using nero7
First you need to locate your music/audio. If it was downloaded from Limewire/Frostwire the default location would be C:\Documents and Settings\**Your Username**\Shared
You can also access your music/audio through Limewire/Frostwire, by going to your Library, then highlighting a file that you want to burn and press explore. This will open the folder containing the highlighted file.
Alternatively use the search to search for something you know is in the folder you want to access or eg. search for the extension of the music/audio you want to burn.
First it may be worth mentioning that there are two ways of burning audio in Nero 7. Using Nero Express or Nero Burning ROM (The original Nero program). I find both very simple to use, but prefer Nero Express, so That's what I will use here.
First open Nero StartSmart:
Pressing add is not necessary. You can also open folders outside of Nero Express, and then you drag and drop the same way.
You can make mp3 disks using Nero Express as well. Just choose make Data Disk instead of Audio CD in Nero StartSmart. The only difference you will see is that instead of minutes you will be adding size (MB)
In case you run into playback issues when using Nero Express, then you have two options. You could try using Nero Burning ROM. Raaf explains here how to do that with Nero 6, but Nero 7 is very similar:
Burning a (audio) CD from your MP3's (Windows)
Another way is to run a tool called CD/DVD Drive Speed (can be found in Nero StartSmart under Tools, where you let Nero burn test disks for checking the best speed for this type of disk.
Aug 03, 2012 | Ahead Software Nero 7 Essentials Suite...
Links dont open in my Outlook 2007, why?
  1. Click Start, and then click My Computer.
  2. On the Tools menu, click Folder Options.
  3. In the Folder Options dialog box, click the File Types tab.
  4. In the Registered file types list, click (NONE) URL:HyperText Transfer Protocol, and then click Advanced.
  5. In the Edit File Type dialog box, click Edit.
    Important Make sure that you note the current values for the fields that are in this dialog box before you go to the next step. You may have to restore the values for the fields that you changed if this method does not resolve the issue.
  6. In the Action box, type open if it is not already there.
  7. In the Application used to perform action box, type "C:\Program Files\Internet Explorer\iexplore.exe" -nohome if it is not already there.
  8. Click to select the Use DDE check box if it is not already selected.
  9. In the DDE Message box, type "%1",,-1,0,,,, if it is not already there.
  10. In the Application box, type IExplore if it is not already there.
  11. Make sure that there is no value in the DDE Application Not Running box. If there is a value in this box, delete it.
  12. In the Topic box, type WWW_OpenURL if it is not already there.
  13. To close the Edit File Type dialog box, click OK two times.
  14. In the Registered file types list, locate and click (NONE) URL:HyperText Transfer Protocol with Privacy, and then click Advanced.
  15. Repeat steps 5 through 14 by using the (NONE) URL:HyperText Transfer Protocol with Privacy list item instead of the (NONE) URL:HyperText Transfer Protocol list item.
  16. To close the Folder Options dialog box, click OK.
  17. Test a hyperlink from Outlook Express.
hope this helpful
Jan 08, 2011 | Microsoft Office Professional 2007 Full...
Whenever we try to open skype a dialoge box apppears showing fatal error failed to load library d3d9.dll.
You will have to re-install the Skype application in order to get rid off the error.
Please follow the below step:
1. download and install the Revo uninstaller application online(It's free).
2. Look for the "Skype" application and select the "uninstall" option.
3. Select "Advance" scan and remove all the remaining files of skype.
4. Reboot the computer.
5. download the d3d9.dll file from the following website http://www.dll-files.com/pop.php?dll=d3d9
6. Copy the d3d9.dll file and paste it at the following location C:\windows\system32
7. You will have to register the dll file before installing the skype application. To register the dll file:
Click on "Start" menu and select the "Run" option or Simply Windows key+R
Then, type regsvr32 d3d9.dll and click 'OK" .
8. Once the dll file is registered, you can install the Skype application and continue using it.
I hope this should fix the issue.
Thanks, Vicky
Dec 27, 2010 | Compaq Presario 5000 PC Desktop
Internal error : couldn't open the second advanced file dialog looks, like you didn't register some DLLs
Aug 13, 2010 | Ahead Software Nero 7 Essentials Suite...
PROBLEM WITH NERO 8 MICRO
i had this exact problem so i uninstalled it and then reinstalled it
good luck
Mar 18, 2009 | Computers & Internet
.jpg files
File associations are made/changed by opening the Tools>Folders> Files window where you will see an option to change that. Steve
Dec 31, 2008 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Internal Error
What version of windows and nero are you using?
Oct 11, 2007 | LG GGCTower 1-to-7 (CO07DVD7TO1TB-0000)...
Ahead Software Nero 7 Essentials Suite Full Version OEM  Logo
1,421 people viewed this question
Top Ahead Software Computers & Internet Experts
celos
lemesee
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
