Question about Nikon Coolpix S3 Digital Camera
I did not use my Nikon Coolpix S3 for quite some time. I had left the battery inside the camera. And did not charge the camera for while. Recently I tried switching it on and I found (i) the camera comes to life but the lens cover does not slide in (ii) many of the buttons are not working.(iii) the charging LED does not glow when I put the camera to charge. I checked the battery and it appeared alright to the naked eyes. Please help. Bidyut Roy
  • Nikon Master
  • 5,412 Answers
Battery needs replacing. All rechargeable batteries need to be charged at intervals, even if not used
Posted on Jun 23, 2017
2 Suggested Answers
  • 3083 Answers
SOURCE: Hi i have Nikon coolpix 5900. Yesterday after
Make sure the battery contacts, both inside the camera and on the battery, is clean. You can clean them with a qtip and alcohol. Also, check the battery voltage, it could be getting old. Here is a good blog of things to check with this problem:
Good luck, and hope this helps.
Posted on Jul 08, 2010
Nikon Coolpix keep resetting Time and Date and menu settings.
I am listing this tip for the Nikon Coolpix 995, but the tip is valid for all Nikon Coolpix models.
The Nikon cool pix settings are saved into an internal memory.
The internal memory is maintained by an internal rechargeable battery, that is recharged from the main Li-Ion battery.
If you leave your Nikon overnight with no main battery, or if the Li-Ion batteries have drained, then the internal battery will also drain , resetting the clock and other settings, saved on the internal memory. The camera may even drain in about 6 hours depending on the camera, normally it takes at least 12 hrs to drain the clock battery.
If the internal battery is resetting immediately, after you set the clock, or just after few minutes, then the clock battery must be replaced.
The camera must be disassembled completely to replace the battery located on one of the two main internal boards.
Nikon says that the clock battery loosing charge is normal. I quote what they say on the publication titled " The Nikon Guide to digital photography with Coolpix"
"Backup battery of the clock
The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset. Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."
Original file: Download here
If the clock does not work at all, and is resetting immediately, even though the Li-Ion batteries are fully charged, then the best thing to do is calling Nikon, at the number listed on the owners manual, telling them that you did not do any improper use of the camera, and trying to get the fault repaired as factory defect. That is not always possible, and the decision depends on Nikon customer service.
See also: Nikon | Contacts
on Feb 05, 2010 | Nikon Coolpix 995 Digital Camera
Nikon coolpix s8100 will not turn on. i have only used the camera a few times, and it was recently charged. is there a manual reset button? or do i need to send the camera back to nikon?
If it won't turn on, you're not going to be able to reset it.
Other than sending it back, the only suggestion I can make is do you have or can you borrow a spare battery. If so, try that. It could just be a failed battery.
Aug 26, 2011 | Nikon COOLPIX S8000 Digital Camera
I have a Nikon Coolpix S3 which I have been using for the last 4.5 years. Recently it has started showing an issue that the display goes blank and the camera stops responding after a couple of shots. I...
I cannot be sure but a 4.5 year old camera 'may' have an old battery. Meaning you charge it to 100% and it has something like 25% total capacity. (Especially if you used the camera a lot) You never see a battery indicator on the display when shooting... like 5 minutes after you charge
Dec 25, 2017 | Nikon Coolpix S3 Digital Camera
My nikon 775 just won't start even after i put in a new battery (i thought it was a battery problem). any clues on what i should do before i retire if permanently?
The Nikon Coolpix 775 can be powered using a EN-EL1 rechargeable battery or a disposable 2CR5 type battery (Panasonic, Duracell, Maxell etc). If you are trying to use an EN-EL1 you may want to try using a 2CR5 - this would prove if the battery charger you are using to charge the EN-EL1 battery is working correctly.
You can also try and check if the contacts inside the battery compartment are clean - the camera is quite old and there will normally be some dirt deposits after that length of time.
Hope this helps.
Jan 13, 2011 | Nikon Coolpix 775 Digital Camera
Can I charge Coolpix S210 via USB cable and wall outlet?
No. In order to keep down the size and weight, the camera does not include the circuitry needed to charge the battery.
Jan 05, 2010 | Nikon Coolpix S210 Digital Camera
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit:
May 13, 2009 | Nikon D40x Digital Camera
Nikon coolpix S3- most of the screen is black on shooting mode
I had the same problem with mine. I searched the web and came across this one. My camera had a black screen but everything else worked. I read some of the comments and a few people said to hit it. I hit the camera in the side of my hand a few times and it started to work. Thanks for the info. It sound carzy but it works.
Now working Nikon coolpix
Sep 29, 2007 | Nikon Coolpix S3 Digital Camera
Nikon Coolpix S3 Digital Camera Logo
49 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
