Question about Garden
Leakage of a trickle of water coming out of the air release valve every 5 to 10 seconds. Purex triton cc100 pool filter
  • russtami22 Oct 12, 2010
    Thanks Bob, sounds like a simple fix.
  • 3,153 Answers
I would start with a new cartridge first to ensure that it is not clogged up or defective..
If you still get the leak after that then check that you are within the operating tolerance for water pressure.
It does sound like a build up of pressure somewhere in the line or it may be that one of the seals is simply damaged or has a build up that is preventing it from doing its job.
Most of these devices are simple to tear down and re-build to check for problems and quite often it is a simple fix. The time between leaks may be of interest if you have a pump or similar operating on a similar time scale as that would maybe indicate the pump was over working and the pressure from the pump may be a little high.
Most of these circuits have test points to be able to fit a guage for basic tests and these guages are not all that expensive. Simple rule of thumb for a meter if to check the specs and find the highest pressure and buy a guage that is at least 1.2 as much as that. So for a max of 100 PSI a 150 PSI guage.
Apart from that filter double check any other filtration devices that may be in the water circuit and if they have back-flush capability perform that too to ensure larger debris is not getting through.
Bob
Posted on Oct 12, 2010
  • Project NOMAD
    Project NOMAD Oct 12, 2010
    You are welcome.
    Hope you get it fixed
Can I fix my input valve, on my sand filter, while water is in the pool?
IF YOUR ASKING IF YOU CAN REPLACE THE MULTIPORT VALVE ON TOP OF SAND FILTER HOUSING WITH WATER STILL IN POOL , SURE ITS POSSIBLE . 1ST UNPLUG PUMP POWER !!!! SECOND USING A COUPLE OF TRASH BAGS ADD ENOUGH AIR INSIDE OF THEM TO FIT JUST TIGHT ENOUGH DOWN INTO SKIMMER ON SIDE (ME I USE A OLD POOL TOY) WEIGHT OF WATER WILL HOLD THEM IN THERE , NOW YOU CAN DISSCONNECT YOUR HOSES , A SLIGHT TRICKLE MAY COME OUT (EASY TO REPLACE LOST WATER VOLUME) REPLACE THE VALVE , WAIT FOR GLUE TO COMPLETLY DRY (IF USED) THEN RECONNECT HOSES , REMOVE TRASH BAGS FROM SKIMMER(LET AIR OUT) , RECONNECT PUMP AND TEST FOR LEAKS
Jun 05, 2015 | INTEX Sand Filter Pump
I have a purex triton sand dollar 60 filter I replaced the sand and when I go to put the top back on the filter it will not go down in all the way if the o ring is bad could that cause it not to go down...
First, try a RUBBER mallet and GENTLY tap the perimeter of the Valve Head Flange to seat the Valve Head into the canister tank. If that does not work, you either need a new O-ring or your canisters center tube is off center or there is too much sand UNDER the canisters internal Filter Fingers at the bottom of the tank.
Hope this helps,
Dan Osko
Osko Pool n Spa
http://www.oskopoolnspa.com
May 11, 2014 | Pool & Spa
Triton Purex minimax 400
dan i belive you have a faulty thermastat switch
Apr 01, 2012 | Pentair MiniMax CH Natural Gas Pool...
Can't get my creepy crawler to work in my pool, i have a purex triton filter system, i can't get any suction on from the crawler
It sounds like your automatic pool cleaner might have a leak that is causing the pump to lose its prime. Check the hose to make sure that there are no leaks or cracks. Check the vacuum connection. It should be submerged so no air enters the system. Look and check the pump basket lid for looseness, cracks, and worn or missing O-rings.
Feb 26, 2011 | Universal Kreepy Krauly In-Ground Pool...
I replaced CVA-24 VALVE....now when I turn on pool filter no water being pulled through..no water being pulled through to pump
Your pump has probably lost its prime. This is either because it got too much air or not enough water. Try priming. This should make your pump start working again. Any time pool pumps have to be services, they need to be re-primed. In case you are not sure how, remove the pot lid and fill the pot with water. Re-add and clamp the pot lid. Open the air release valve on the filter and stand clear. Turn on switch or time clock. When water comes out of the air release valve, close the valve. If it is a two speed pump, make sure it is on high speed.
Aug 20, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Purex triton powermax 400- gas ignites for a moment and then shuts off - basically cycles on and off for the spa. any idea to the problem?
This is usually either the Thermal Overload Cutoff (an inline fuse to prevent overheating) which costs $13.50 through poolcenter.com, or it is that you are not getting enough water pressure through the heater. There are sensors that will shut down the heater if there is not enough water flow. Is your filter clean so enough pressure/flow is happening?
Feb 15, 2010 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Triton minimax 400 pool heater won't ignite
Make sure the gas valve is set to on and thermostats are set properly. Check the pressure switch and high limits for continuity.Check wires for signs of damage, etc..
Jun 27, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Jun 05, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
