Question about Sharp EL-1801P Calculator
What ink roller does it take - Sharp EL-1801P Calculator
  • 14 Answers
Part# IR40T
http://www.gorillapaper.com/ink-roller-ir40t-b-r.html
Here it is
Posted on Nov 05, 2010
How do you change the ink roller in a TI 5005 ii
Replacing the Ink Roller
  1. Press the OFF button.
  2. Remove the printer compartment cover.
  3. Remove the ink roller from the right side of the compartment. Insert your index finger, nail down, under the tab on top of the ink roller. Gently lift the ink roller out of the compartment.
  4. Lower the new ink roller (IR-21) into the compartment and align the hole in the ink roller with the pin in the compartment. Press down until it snaps into place.
  5. Replace the compartment cover.
Warning Never refill or moisten the old ink roller. This can damage the
printing mechanism and void the warranty.
The full manual can be found here:
http://www.retrevo.com/support/TI-TI-5006-II-Calculators-manual/id/426ci758/t/2/
Nov 18, 2013 | Texas Instruments Office Equipment &...
Replace ink cartridge
INK ROLLER REPLACEMENT
If printing is blurry even when the ink roller is in the proper
position, replace the roller.
Ink roller: Type EA-732R
WARNING
APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS
DAMAGE TO PRINTER.
1) Turn the power off.
2) Remove the printer cover. (Fig. 1)
3) Remove the ink roller by turning it counterclockwise and
pulling it upward. (Fig. 2)
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place. (Fig. 3)
5) Put back the printer cover.
Jun 08, 2012 | Sharp EL-1611P Calculator
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
I have a Sharp EL-1801P that is low on ink. Can I add ink to the roller or do I need to buy a new roller?
Ink roller: Type EA-772R
WARNING: APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS DAMAGE TO PRINTER.
1) Set the power switch to OFF.
3) Hold the top of the ink roller and remove the roller by pulling
it toward you and then upward. (Fig. 2)
4) Install the new ink roller in the correct position. Make sure
that the roller is securely in place. (Fig. 3)
Feb 08, 2011 | Sharp EL-1801P Calculator
How do I replace the ink cartridge?
1. Press OFF.
Feb 04, 2011 | Texas Instruments TI-5006 II Calculator
How to change ink roller on Sharp Calculator EL-1611H
pulling it upward.
Apr 19, 2009 | Office Equipment & Supplies
Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Nov 20, 2008 | Canon P170-DH Calculator
Ink rollers
Unless the ink roller that you installed was dried out, usually, the replacement rollers just snap in place and are good to go. Check to make sure there is ink on the roller by either pulling the ink roller out again, and touching it with your finger. If no ink on your finger, you might have received a dried out replacement roller. Also the roller should be somewhat like a sponge. If you push against the sponge and it doesnt spring back and it stays indented, then the roller might also be bad. If you happen to have a bottle of ink for an ink pad, you can try soaking the roller with the ink so the roller is wet, (but not DRIPPING WET) and try it again in the calculator. IF you get some image for a little while, then I would say try a new fresh ink roller.
Hope this helps.
Feb 04, 2008 | Sharp EL-2192Rll Calculator
Sharp EL-1801P Calculator Logo
49 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
