Question about Toto Home
I have a TOTO MS854114SL AFTER THE FLUSH, WHEN THE TANK STARTS TO FILL UP IT HUMS VERY LOUDLY UNTIL FULL
  • 10,865 Answers
What you hear is the washer vibrating against the ballcock seat. The reason it stops when you turn the water on is that you have lowered the pressure by opening a valve. You can go at this two ways. (1) you can lower the pressure by turning the angle stop located below the tank until the noise stops or, (2) you can shut off the stop and remove the three screws on top and cup your hand over the top and just crack the stop enough to flush out any trash that may be in there. After you do that pull the washer out of its holder and flip it over in its holder and reinstall the top and float. One of the two should do the trick. If not click on back and
replace the flush valve. Joe
Posted on Oct 12, 2010
The water in the bowl keep runing after the tank is full.
fill valve not shutting off water running over overflow tube set or replace fill valve flapper valve leaking replace flapper valve cracked and leaking flush valve assembly replace
Sep 18, 2010 | Toto Promenade, 1.6 GPF, Elongated...
I have a toto toilet that doesn't start to refill until a couple of minutes after I flush. Any ideas. Thanks.
Several ideas. Start to fill? Have you looked inside the tank to see what's going on? If it just filling very slowly, then you most likely have some calcuim build up inside your flush valve blocking some flow, if this is the case you will have to clean the flush valve. If your flush valve is staying up and the toilet is "running" unitil the float drops. The float (either the arm ballcock style, or newer fluidmaster) is rubbing on either the flush lever or side of the tank, and taking longer to drop to let the water start flowing. I
Jun 23, 2010 | Toto Toilets ST784S 12 Sedona Beige...
Changed the flapper on my toto toiet and yet still there is a hissing from the fill valve, any suggestions?
changing the flapper will not help the fill valve if it is not shutting off. It is not shutting off all the way once the water fills up, you either need to replace the seal in the fill valve or replace the fill valve. They can get grit in them or get scaled up and they stop working properly.
Oct 21, 2009 | Toto Ultramax One Piece Elongated Toilet...
Water want stop pouring
remove lid from tank.see that 'flapper valve' in bottom of tank is seating to stop flow into bowl.adjust chain linking flapper to flush handle. replace worn or broken parts
Oct 01, 2009 | Toto Toilet Onepiece Ultramax ...
Toto runs non-stop; won't shut off
float is sticking make sure it is moving up and down.or the float is set to low, the lower the float is higher the water level is.
Mar 24, 2009 | Toto Toilet Onepiece Ultramax ...
Delay on tank fill after flush. Toto Drake bowl ada elongatred
I am not a plumber but stumbled across the solution on my own. While watching the float during the flush cycle, it was obvious that it was very slow in moving downward along with the water level in the tank. The problem was that the small opening in the float chamber was partially clogged. Using just my fingers, I reached under the float chamber and cleaned off any debris that was blocking the opening underneath the float chamber. Put the float back on, and instantly the problem was solved. The tank fill started immediately after I flushed.
Mar 09, 2009 | Toto Drake ADA Compliant Toilet with...
Home Logo
302 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
