Question about Freezers
What number should my freezer be set at as it doesn't seem to be freeezing properly
  • 316 Answers
The normal setting for any residential refrigerator or freezer is the middle setting of the scale. If max setting is 9, middle would be 5, If max setting is E, middle would be C etc.
Posted on Oct 12, 2010
What number should i set the upright freezer control
Thank you for your inquiry, friend!
Normally it is recommended to set your Frigidaire upright freezer to zero degrees. It is your option to make it cooler if you choose too. I hope this information has been helpful. -Matt
Oct 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Igloo chest freezer 7.2 cubic ft seems running all the time?
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
Apr 30, 2014 | Igloo Cooler Igloo - 5.2 Cu. Ft. Chest...
Kenmore freezer gets cold and freezes but then completely dethaws itself
usually when aq defrost timer goes bad it gets stuck in defrost. I would suggest replacing this first
Mar 29, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I purchased this Frigidaire freezer three years ago. Around a week ago, I noticed that the items I had stored in the freezer have begun to thaw slowly. Although the freezer is still "working", it...
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for icw build up. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Jul 23, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The red light is on my freezer also the green one the door has not been left open can you help
This means the sensor has determined that the temperature is rising. This can happen if the door was left open (which doesn't appear to be the case with your green light) or an unusual amount of warm food was put into it. If this is not the case you may have a cooling problem. If you can put a thermometer in there and check the temperature, working properly the freezer should be around 0 F. If you have trouble please send the model number from the tag on the freezer. That will help with trouble shooting.
Jun 07, 2011 | Whirlpool 10 cu. ft. / 283 liter Chest...
What is the proper setting on my freezer that has a dial of 1 to 7? My products seem to get iced over.
Sorry to hear about your problem.
Sounds like you have a defrost issue. 5 is a good number, what ever it takes to keep you freezer at zero. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Freezers
I have a Frigidaire ffu1466gw0 Upright Freezer. It is a frost free freezer and doesn't seem to be cooling properly. Some items seem to be solid enought, but ice cream is melted for the most part. I have...
if the compressor is running, the fan beside the compressor and the fan in the freezer should both be running, dirty coils can cause a problem. frost buildup on back of freezer wall is indicative of defrost problem.
Jul 26, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Whirlpool FUF20DPARWH Freezer
Was the door left open for a long period of time.? Sometimes this causes so much ice that it re freezes and can't clear the drain. The only solution is to unplug and let sit with doors open for at least 24 hours. to get all the ice off the coils. Then use a pipe cleaner on the drain then use a turkey baster to force water through. then a mild bleach solution. Check the door gaskets if they are ripped or loose or the door warped and not sealing tight this will also cause this problem. If this still doesn' t solve the problem it is probably a defrost problem Usually the timer or defrost thermostat.
May 18, 2008 | GE 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
1,537 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
