Question about Kitchen Ranges
I have a Valliant 828E ecomax bolier. I've had it for three years and it has been perfect. The only slight issue is that, perhaps once a year, I need to refill it by opening the taps at the bottom. I did this yesterday, and now the boiler is dripping (mainly down the left hand side as you look at it, the opposite side from the taps). The boiler maintains the pressure I increased it to (I don't think I did it too much - it's nowhere near the maximum) and when I switch the mains off the dripping stops. I'm guessing that the connection from the mains water to the bolier is loose, and I loosend it when opening the taps (one of them was very stiff). My question is, what is the probable problem and is it possible to fix it yourself or do I need a professional?
  • jonparsons14 Oct 12, 2010
    Hi - I've just refilled my Valliant boiler using the two taps at the bottom of the bolier. Now there is a drip coming from somewhere - but it's definitely something to do with the mains - as the boiler maintains pressure and the drip stops when I turn the mains off. I'm suspicious because it's only started happening since I refilled it. The drip doesn't seem to be coming from the taps but higher up.
    How would I trace the leak and is it something I could fix myself having had little experience repairing boliers?
  • 3,866 Answers
The issue here is allowing a boiler to drain/refill what has happends in there is a little piston on the relief valves (hope where on the same page) When these become loose you got the leak at the mains.
Quality repair? YES
Do it yourself? Depends on your experience?
I would:
1. investigate the leak
2. trace the leak
What you can do if its a leak at the means is refit the inlet or you might need to buy a new piston @ the releif valve, I am not there so it hard to make a educated quess on where exactly you have your leak not everyones left hand side is invident on location of where the leak is coming from. If I saw where the leak was I can give a better more in depth answer to your question and possiably help fix the leak.
My answr/advice would be at the mains.
Thanks for your question I hope this does help please do click the accept button for mt efforts.
Yes I have installed a boiler before! Done it a few times..
Posted on Oct 12, 2010
  • Grand Canyon Tech
    Grand Canyon Tech Oct 12, 2010
    If its comming from the tope i would have the mains investgated not something you can do yourself if the issue is not comming from the taps.
    I feel i more then tryed to help you here I love answering questions but this is something complex where the leak will need to be found ultimatly i would not expect you to expect me to locate the leak via email?
    But the mains is where the issue is at
  • Ben Dover Oct 21, 2010
    LOL rudy, why dont you help the guy set it up the way its suppose to be, you know, the pressure and how to set it up, blah blah blah...thats a good place to start if its actually the safety leaking.
  • Kitchen Ranges Master
  • 3,083 Answers
Here is a web blog about this problem, but this one elevated into a large leak. It's to do with the way the connections use clips, and this fellow that wrote the article thinks it's a design issue. Here's the blog:
http://www.diybanter.com/uk-diy/5093-warning-vaillant-ecomax-6-8-series-boiler-owners.html
I couldn't find any reports on exactly how they repaired the problems, so I think they just reseated the clamps, and so getting to them will require some disassembly.
Take your time to figure it out...everything that went together usually comes apart by undoing the fasteners. Keep track of which screws go where, in case they have more than one size.
Good luck, and hope this helps.
Sharp CV-P12Px not cooling
Sounds like an issue with the compressor. Have a service technician test the compressor.
Apr 30, 2012 | Sharp CVP12PX Air Conditioner
Hobrat ecomax 602-10 not working
The most common problem with HOBART ECOMAX is blown site fuse. The problem can be fixed by checking site fuses.
Apr 19, 2012 | Dishwashers
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Ok well my Samsung Stunt Sch-100 was working perfect for the first year or so i had it. but recently it shut off and i would occasionally able to turn it on. but now it wont turn on at all! Any...
check the battery if you've had the phone a year chances are the battery is defective, cell phone battries usually last only 200-300 charging cycles have it tested by a battery dealer or just replace it once you get it to turn on make sure your charging port is charging the phone
May 12, 2011 | Cell Phones
I HAVE A 2008 KINGPIN AND IT EATS BATTERIES. A NEW ONE EVERY YEAR. IS THIS NORMAL. ALSO THE BATTERIES ARE REALLY EXPENSIVE. WHAT TYPE OF BATTERY DO YOU RECOMMEND.
Make sure your battery spec is 12V/18 amp hours. If you can fit a slightly higher amperage battery into the space, then the longer the battery should last. The Kingpin can charge 38Amps maximum.
You could also change the brand of battery IF you have bought the same over the last two/three years. Some batteries are inferior to heavy starts, even though they look fine.
Starting a 1634cc engine cold takes a lot of current. Each start, damages the battery ever so slightly, ending up in failure. Also check that there isn't any heating issues between engine/exhaust and battery case. Hot batteries die fast!
Feb 13, 2011 | 2008 Victory Kingpin
My friend stole it and he says he doesn't have it my Ds name is Shana
I HAVE LOST MY REMOTE THERMOSTAT AND CANNOT TURN HEATING ON. PLEASE TELL ME WHAT TO DO. MANY THANKS. ITS AN ECOMAX VALLIANT BOILER.
Nov 21, 2009 | Nintendo DS Console
Valliant ECOmax boiler is not giving me any hot water
My Valliant Ecotec Pro Combi Boiler (approx 4 years old) does not start up. The fault code showing is F.22. I would be grateful if you could let me know what the problem is and obv how it can be fixed. Thanks and regards, Joanne Byne
Jul 03, 2009 | KDS Valiant 6380iPTD-01 Notebook
Boiler problem
check the air flow,venturi in fan and pressure switch
May 16, 2009 | Sun Time NCAA Purdue Boilermakers...
M-Audio BX8 blows a fuse
If your monitor is crackling and fizzing, that is not a fuse issue, unless the fuse you have installed is underrated. It sounds like you have a bad driver/woofer, and need to get it replaced. CLICK HERE FOR THE REPLACEMENT DRIVER for this model.
- DJPA
Jul 05, 2007 | M-Audio Studiophile BX8 Main / Stereo...
Kitchen Ranges Logo
123 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
