Question about BOB Trailer Baby Gear
I bought this stroller in 2009 in June. It's giving me problems sliding the seated position to folded position. The licks that click when you pull the stroller up don't quite click and I have to force the stroller by hand to click to lock. Same happens when I want to fold it back to store it, it only folds the first half and the second half gets stucked...I manually have to wiggle the sides to cause it to fold. Any way to trubleshoot it or should I seek professional repair help. ?
SOURCE: folding graco stroller
how to fix the strooles directions
Posted on Sep 27, 2008
SOURCE: How do I fold up DuoGlider???
Folding up duoglider. Fold the botom basket down. I always take off the front wind breaker ( infants cover). It will just pop right off. Then locate the front handle of glider, slide red button to the right and twist.
Posted on Jan 18, 2009
SOURCE: Folding Quinny speedi Sx Stroller
In the middle of the underneath of the pushing handle, below where the hand brake lever is there should be a button. If there is, this is what you do.
1) put the foot brake on so the rear wheels wont turn.
2) unclip the clips on the frame that allow you to adjust the height of the pushing handle, they open up, and leave them open, like this the handle you push the buggy with should slide up and down.
3) pull this handle out to its tallest position
4) Hold the handle and press the button mentioned at the start in and hold it in
5) Then quite quickly push the handle down as though you were either pushing it to lower its pushing height, or shoving it away in a temper. It needs to be a firm and quick movement.
Ta da!! After a couple of tries it should click and fold up.
I hope this helps.
Posted on May 13, 2009
SOURCE: fold stroller
Not sure how different this one is to ours but we have an older Dreamer Design double stroller and down by the front wheel there are two black plastic clips that you pull upwards while at the same time pushing two small depressable "buttons" that are in line with the main bars coming down towards the front wheel... once that's done you lift and push backwards at the same time, the whole stroller frame will move backwards (oh brake has to be on) and then once those main bars are free you can pull the frame towards you and then double it over back on itself...the rear wheels pull out by pushing the centre button and pulling on the wheel and they you're able to put it just about anywhere...hope that helps...Rob
Posted on Sep 22, 2009
SOURCE: Issues with Uppababy vista stroller folding mechanism
You have to press the button on the left side while pushing the handle in at the same time.
Posted on Nov 05, 2009
Graco alano not folding? the push and twist handle not turning?? so the stroller does not collapse or fold. how can i get it to fold. wife needs to travel back and i am not sure airline would allow her if...
Took a while but finally figured it out. Original thinking was that the problem is in the handle twist and release mechanism. The problem actually lies in the collar where the unit locks into place. If the stroller is in the open position it can't be fixed unless it's folded up. To open stroller without the twist handle -- locate both black spring loaded collars where it locks into place (approx outside where the seat and seat back meet). Manually pull both the collars up the shaft. The spring is tight and it may take an extra set of hands to get the right leverage. Once the unit is in the folded position -- flip the stroller upside down and blast WD-40 into the hole where the spring pins are and work the black collar up and down. The twist mechanism on the handle will now work. My daughter claims it didn't even work that good when the stroller was brand new and we saved the time and trouble of shipping the entire stroller and seat system back to Georgia just to let the Graco people decide what to do. Bottom line is that this mechanism design stinks from the get go. Hope this helps.
Oct 12, 2012 | Graco Alano Travel System Stroller -Greer
We can't get the stroller to fold correctly, it worked once but we cannot get it to fold again.
I can't get my First Years Wave stroller to fold close. I have handle positioned down along with back wheels. Then slide red button, pull on handle/lever thing, but it doesn't fold the legs down. HELP PLEASE!
May 18, 2011 | First Years The Wave Stroller Crimson...
I can,t break it down to put in my car. what can I do
Hi, If the problem is in the construction you will only have the option to ask the retailer you've bought it from.
If your question is how to fold it:There are two white "Buttons" you can find halfway the main tube, were the push-bar is attached. One button which you have to pull with your forefinger and hold it while pushing the other button (on top) with your thumb and hold it. The place your foot on to the white narrow "strap"/button on the grey base below until it loosens to fold. If you follow these steps and slightly lift the lift the stroller it folds. ( just the section below)
The triangle white button on top can be pulled to slide the main tube in/out (slide while pulling)The white button can be pushed to change the position of the push-bar.
Hope this helps!
Apr 16, 2011 | Stokke Xplory Stroller
How do i fold down my quinny buzz
Hi you need to apply the brake 1st. then stand at the front, there is 2 grey buttons either side of the seat on the 2 round bits. 1 you push down the other you slide forwards, keep hold of them & pull it downwards towards your feet. This will then fold down.
May 14, 2010 | Quinny Buzz Three Wheel Stroller
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
Packing Stokke Travel Bag with the Chassis - bassinet
Hope I can help you out with this...for me it was quite easy once you get the hang of how to fold the stroller system at the smallest possible fold. You have to have the seat at the lowest position, next you fold the front wheels inward so that it is flat against the stroller, then fold the handle all the down toward the stroller frame so that it is flat. NOW you have the stroller at the smallest fold. Remove the SEAT from the Stroller frame and place it on top of the stroller (FYI - the adjustable foot plate should still be attached to the SEAT and it fits directly ontop of the 2 metal pieces that protrude from the stroller that you normally instert the seat into)
NOW it will fit inside the Stokke Travel Bag.
Apr 06, 2009 | Stokke Xplory Stroller
Laying Down and Folding Maclaren Triumph Stroller
Folding takes some getting used to, broke the first one I had because I used force. Here are some step by step instructions...http://www.strollerreviewguide.com/how_to_unfold_and_fold_maclaren_stroller_step_by_step
-Good Luck!
Feb 10, 2009 | Maclaren Triumph W0806063 - Navy Umbrella...
Jan 17, 2009 | Graco DuoGlider LXI 7951GGG Twin Seat...
Quinny zapp, how to open & fold?? really struggle with it. there must be an easier way
I find to fold it, I place my foot on number 3 and push a little then press number 2 and 1 and the same time and fold the seat unit. Then just push down ontyo it untill t is fully folded. I find it to difficult to press 1 then 2 then 3 - 3 always gets jammed if i follow their instructions.
To unfold pull number 3 untill it clicks then nfold seat unit an click the middle handle - hey presto buggy shuld work :)
i thk the instructions tey give a more work than needed.
Aug 14, 2008 | Quinny ZAPP Stroller
Mutsy Urban Rider
Hi guys, I had this problem when I first got my urban rider - the trick is to put the seat on correctly in the first place. If you look under the front of the seat (when seat is facing away from mum/dad) you'll see 2 plastic hooks - these need to be hooked over the first horizontal bar of three that you can see (it has a small black plastic nobbly bit on it) then, as you were doing, push the handle and pull the 'tube'. If the seat is facing you (child travelling backwards) it won't fold, neither will it fold with the carry cot attached.
Hope this helps! Tegans mum x
Feb 14, 2008 | Mutsy 4Rider - Pink Stroller Frame
Baby Gear Logo
212 people viewed this question
Top BOB Trailer Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a BOB Trailer Baby Gear Expert? Answer questions, earn points and help others
