Question about Dell 3000cn Laser Printer
I need to set a static IP for a Dell Laser Printer 3000cn
SOURCE: Dell Printer 3000cn - Back Panel won't close
Have had that happen. Only you can do is give it a good slam
Posted on Dec 10, 2007
SOURCE: will not restart 010-397 states restart printer
I had same problem and called Dell- The 010 errors are all related to the fuser (the thing at the top rear of the 3100) All they had me do was open the rear top cover, pull the outer blue clips and "unplug" or remove and reinstall the fuser. That cleared the error.
Tony.
Posted on Jun 27, 2008
SOURCE: DELL 3000cn Printing Problems
I have the same problem. Test out all the suggestion above. It did not help. I went thru the diagnosis test for all colour. The streak happens on all colour. It mentioned it would have been problem on the laser unit. Does it mean that it is no way to correct this without big expense like purchasing a new one?
Posted on Jul 09, 2008
  • 158 Answers
SOURCE: Dell 3000cn drum cleaning?
Do not try to clean the drum. The drum and its asociated cleaning blades and other parts, are COMSUMABLES that have a certain useful lifespan, the same as batteries or automobile brake pads. When smudges appear on the drum, it and the associated parts are at the end of their useful life. Order a new IMAGING DRUM KIT from www.dell.com
Posted on Aug 06, 2008
SOURCE: Dell 3000CN Laser Priner
Take out paper tray. Stick hand in and rotate mechanism on top back where paper feeds in. It always gets stuck. Fixes our printer every time.
Posted on Feb 10, 2009
Dell 1710n need cd
Hello you can download the installation software here:
http://www.dell.com/support/drivers/us/en/04/Product/dell-1710n
Please select your windows system.
Remove previous installed programs, before you install the new software.
The setup for the static ip, you have to select this under the install of the printer program.
Good luck
Feb 01, 2013 | Dell 1710n Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
May 06, 2010 | Dell 1720dn Laser Printer
Unable to connect Dell 3000cn to wireless network (cable from printer to Linksys router). Printer shows ICP address, laptops set to share files, but computers do not "see" printer at all. Ideas?
The printer driver needs to be installed and the printer port changed from LPT1 or USB to a TCP/IP port.
Please refer to my tip on Setting up HP network printer. the principles are the same for setting up network printers with a print server.
Dec 02, 2009 | Dell 3000cn Color Laser Printer
My Dell 3000CN is out of yellow toner
located in your control center for the dell printer is an option to print in black and white onlhy. click that u should be able to print.:)
Sep 07, 2009 | Dell 3000cn Color Laser Printer
Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Aug 06, 2009 | Dell 3000cn Laser Printer
Hi I get a message on my dell 3000cn that says out of memory press set I have searched, but cannot find what to press to clear this memory.
Ok, I chatted with Dell and after we tried the other suggestions to no avail, the guy said that I need a new ESS board ... wow, expensive! So, found a printer on e-bay to get for parts ... but need info on how to replace ESS board ... can anyone help? Thanks!
Apr 14, 2009 | Dell 3000cn Color Laser Printer
Printing
Try the settings in the printer.
Push Menu button till you see menu
then the down arrow around the enter button till you seetray settings - hit enter
go the paper size - hit right arrow
hit down arrow to the MPF then hit right arrow
then down arrow to change to "letter" size
Good Luck
Aug 15, 2008 | Dell 3000cn Color Laser Printer
Dell 3000cn Network Connection not working
First of, the ethernet must be 'on'. If dhcp available, set it to auto (or dhcp.. anyways..) and let it reboot, just in case :)
if not, try setting the IP-setting yourself. They should be somewhat similar to the settings on your local computer(s).
To add the printer to your computer, select 'Local' printer and specify 'tcp/ip' as which port its connected to. In the new window the ip to the printer should be entered. :) (at least for XP this is..)
Hope this gave you the correct solution..
Mar 18, 2008 | Dell 3000cn Laser Printer
Dell 3000cn Laser Printer Logo
69 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
