Question about Whirlpool Dishwashers
Just bought a dishwasher last month, the manual has "W10142781B" Type no. 575-0 Mod, gu2275xtvy1. The washer will NOT empty after a full wash. There is standing water in the tub. I looked at the drain line and it is free and not blocked in any way. Any advice? Thank You Keith
BIKER T
  • 909 Answers
SOURCE: Pump won't stop draining
you will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
Posted on Oct 08, 2007
hotuna
  • 288 Answers
SOURCE: kitchenaid dishwasher - water standing at end of cycle
How much water are we talking about? If its say less than 2-3 cups, It may be the way it is plumbed to drain. The drain line is back washing a little after everything is finished.
Posted on Dec 03, 2007
ginko
  • 19396 Answers
SOURCE: Water not draining completely from Dishwasher tub
That usually happens because of a faulty water level sensor, check it out.
Posted on May 21, 2009
SOURCE: Water didn't drain, left in bottom of washer tub
I had similar problem and it ended up being a clog at the point where the drain hose meets the garbage disposal. I had to unhook the hose and clean out the food that had accumulated (horrible smell). You may have to stick a screwdriver into the garbage disposal hole where the hose fits and clean the food out there also. Then put the hose into a bucket and run a few cycles to ensure the hose is free.
Posted on Aug 05, 2009
  • 3 Answers
SOURCE: Standing water in dishwasher
This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
Posted on Sep 20, 2009
Testimonial: "Quick response. Thank you."
Clogged drain in frigidaire dish washer
Hello Ian Younker - When did you last clean the filter? Most dishwashers have a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, pits, etc. You should simply be able to grasp handle, lift out, empty and place it back. Also is the unit making a grinding noise? If so, I personally will recommend consulting a professional because you may possibly have a defective drain motor.
Feb 20, 2013 | Frigidaire Gallery Series FGBD2451KF Full...
User manual for Kenmore dish washer Mod#665.13842K601 Type 575-0
You can download th manual for free at the following Kenmore Support link
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0608085.pdf
Sep 09, 2012 | Kenmore Dishwashers
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
I just bought a Whirlpool Gold Dishwasher Model #GU2275XTVY1. Is there a different handle to buy because it is to wide and now I can not open my draws. Any ideas?
Contact the store for the manual or way out in other to avoid damage on your newly washer.
Please rate four tom if it help.
Good luck
Dec 13, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Water filling then emptying again right away
Take the cover off, as you face unit on right side follow the vacum hose to two presure switches. Tap on them lightly with a the handle of screw drive. fix my unit three months ago still working. The problem is the presure switch.
Dec 08, 2007 | Danby 22 in. DDW396 Free-standing...
Water in bleach/fabric softne compartment
Purchased the duet washer and dryer sept 2004..have had the same problem with water staying in the compartments. while under warranty had to place 2 service calls..the last tech order a new bleach compartment...that helped for a few months, but back to the same problem with having to pull entire container out and empty..i do remember the tech saying that whirlpool duet was first introduced in germany...then the united states...they have had the same problem...and that whirlpool is awhere of it, but nothing can be done about...except keep emptying compartment when it fills with water...our neighbor bought a duet washer last fall...no problems like we are having..whirlpool must of solved that issue with the newer versions.... paying $1000.00 for a washer and having to empty the compartment everytime doesn't make sense to me.
Dec 12, 2006 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
106 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
