Question about AOC LM729 17" LCD Monitor
Image comes for 3 or 4 seconds and them goes off for 20 or 30 seconds. This is repeated again and again.
  • 11,361 Answers
Check the DC filter caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 12, 2010
Image goes black and then returns shortly after
Many sets that use lamps do this right before the lamp fails--average life is 2000 hours or 2 years of normal use--if no blinking lights suspect the lamp first.
May 29, 2012 | Televison & Video
I have a Vaio PCV-W20, and a few months ago the screen went black. The problem is that now I only get a visible screen for a few seconds and it goes black again. For example this is what I see when the...
Ok try this, at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems.
support.microsoft.com/kb/306084 -
Jul 21, 2010 | Sony VAIO PCV-W20 PC Desktop
Monitor comes on but then shuts off in about a second
Try reducing the resolution (boot at safe mode)
Stelios.
Feb 22, 2010 | Dell UltraSharp 1908FP Monitor
While riding the check engine lite comes on,causing a little flutter in it's running,then the lite goes off and engine runs smoothly,however, it happens again and again
Check for trouble codes to find out what is happening. To retrieve trouble codes,turn ignition to run for 3 seconds then off for 3 seconds. Repeat this. then turn ingition on and wait about 8 seconds. there will be a number of flashes (about 3 per second) from the check engine light then a 2 second pause then it will flash a code. There will be a 1 second pause between flashes for a digit more than the value of one and a 2 second pause between the first digit and the second digit. All trouble codes are two digits. After you get the trouble code, contact me and I can advise you what it is related to.
Nov 12, 2009 | 2001 Harley Davidson FXST Softail Standard
VA1930WM monitor turns on, displays normal for one second then goes black. Then it turns on again after a minute or so for one second and goes black. This keeps repeating over and over. Is there a known...
If it was the power supply, the light would change to amber (orange) and then turn green again when it comes back on. Look closely at the screen when the it looks to turn off. See if you can still see an image. It may be hard to see, but when the backlights go bad or fail, the actual lcd screen itself still functions and you can see a very faint image. Maybe moving the mouse in circles might help you to be ablt to see. If you cant see anything at all, then it may be a bad board inside the unit.
Just a thought....
Sep 18, 2009 | Computers & Internet
Screen goes black on my hp pavilion dv4000 notebook
Try connecting an external monitor to the laptop, power up the monitor first then boot up the laptop. The video data will switch to the monitor automatically, check if the monitor dislays a normal image and see if the image stays on the monitor.
Also press and hold the Fn key and press the F4 key, these keys toggle the video output between the LCD screen and the video port.
Test to see if this functions correctly.
Get back to me with the results of the tests.
Jun 03, 2009 | HP Pavilion dv4000 Notebook
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
Will not come on
Check capacitors 3 of them cp150 2200uf 16v if it is bad set will not turn on other 2 caps will be next to it 220uf 35vs.cp111 cp114 cp120
Dec 14, 2008 | RCA D52W19 52" Rear Projection Television
AOC LM729 17" LCD Monitor Logo
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
