Question about Brother HL-5240 Laser Printer
How to reset the drum counter? - Brother HL-5240 Laser Printer
  • 1,110 Answers
Drum reset procedure:
Open toner door, hold down go button until all lights are on, let go of button, close door, push go button. Will reset drum counter to 100%.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Oct 12, 2010
Monolta izhub 362 hwo to reset drum counter
Bh 362 is the upgrade of Bh 200, 250 and 350 and on that model you need change drum and developer together. The drum counter message can be reset in service mode by a qualified tech after replacing those parts.
Aug 23, 2014 | Konica Minolta Bizhub 362 Copier
Reset konica drum counter
has it been replaced???????????????????????/
Has the drum been replaced? If not reset code for drum without replacing the drum is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items, then the copier will adjust certain voltages to certain items such as the drum as those it is new because you reset the counters when in fact the drum is old and so you might be codes and image problems.
Feb 13, 2014 | Konica Minolta Office Equipment & Supplies
I have a Brother MFC-9180, it has a DR8000 in it. The machine come up on the display saying "Change drum soon" which I have done, the new drum did not come with a page to feed into the drum. I want to...
Did you reset the drum counter?
When you replace the drum unit with a new one, you need to reset the drum unit counter by completing the following steps:
  1. Turn the the machine's power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
I hope this helps.
Or Try this:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/002800/000037/faq002837_009.html?reg=as&c=au&lang=en&prod=mfc7220_us_as
Oct 20, 2013 | Brother International Brother MFC-9180
Drum reset counter
When the drum is replaced the counter on the DP-C264 automatically resets. If it does not reset then the flag on the back of the drum has been damaged in shipment or during the install of the drum.
Oct 11, 2013 | Panasonic DP-C264 Color Copier
How do I reset drum counter on brother printer HL5250dn
Hello. if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Regards, Joe PS: kindly rate my answer. Thank you.
Jan 28, 2010 | Computers & Internet
Reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Sep 15, 2009 | Muratec MFX-1430 Copier
Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Reset the drum counter only when you replaced the drum unit with a new one.
Aug 03, 2009 | Brother HL-2040 Laser Printer
Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  4. close front cover
Mar 23, 2009 | Brother HL 1250 Laser Printer
How to reset drum counter for fuji xerox 203A
Aug 28, 2008 | Office Equipment & Supplies
Dell 1700 image drum
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button until all lights flash in sequence.
Dec 13, 2007 | Dell 1710n Laser Printer
Brother HL-5240 Laser Printer Logo
626 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
