Question about Car Audio & Video
Hello I have a freelander car radio the reception is poor ,no AM only buzzing FM is very variable it just has a cassette/radio any suggestions please
leethedeuce
  • 4472 Answers
SOURCE: I have recently fitted a
check the ground.
Thanks,
Lee
Posted on Jun 30, 2008
SOURCE: WHY CAN'T I GET AM RADIO RECEPTION - ONLY FM??
You need a seperate AM antena for your AM radio to work. If you look on the back of the system where the FM antenna is connected you will see a AM hole for an antenna. I had same problem hope it helps!
Posted on Nov 08, 2008
blueextc3221
  • 15935 Answers
SOURCE: poor AM car stereo reception with new DP AudioVideo player
AM.... what the heck is AM??? LOL
Check the antenna connection behind the radio to be sure it is taped and not touching ground. Also the antenna & cable running to it for worn spots in the shielding, or corrosion.
I think (based on knowing how manufacturers do things at times) that their is a very cheap universal chip type tuning system in play here on the order of about 10 cents value that many manufactures are probablly incorporating these days. What I did to solve this annoyance was to purchase (after many tests) a SHARP brand walkman type AM/FM hand unit that has really good AM and jack it into the preamp section before my crossover (added an extra input via Y-adapters) and use Ni-metal-hi batteries that can be recharged. I get about a week out of the 2 AA cells. I also had to build a rather good cable (shielded) to go from the unit to the 1/8 jack to cut noise a notch more. This has proven a good situation for me.
With this knowledge, I wonder what head units actually have good rejection circuitry and great gathering power for amplitude modulation?
Posted on Jan 08, 2009
awcforever
  • 359 Answers
SOURCE: no am reception and poor fm reception - 2004 Kia Sedona
If the antenna is on the front, pop the hood, and locate where the antenna wire connects to the bottom of the antenna and make sure it is connected well. If everything checks out there, you will have to pull the radio from the dash, and look at the back of it. There will be a large black wire by itself connected to the radio. Push it in to make sure its connected as well. That could really be your only problem unless your radio happens to have a fault on the inside which is extremely rare. Hope that helps
Posted on Mar 15, 2009
  • 518 Answers
SOURCE: Poor tuner reception
THIS IS NORMALLY DUE TOO BAD EARTHING, MAKE SURE YOU HAVE A GOOD CLEAN EARTH ON BODY
Posted on Jun 13, 2009
Very poor radio reception
FM reception depends upon having a good antenna matched to the radio. What type of radio are you using, and what are you using for an antenna?
May 02, 2015 | Golf
Lumina radio has poor am reception
AM radio is gone with the wind Cheryl,have to be home and play with antenna,remember them days,the 70's,lol.
Nov 28, 2013 | 2001 Chevrolet Lumina
Fm reception for weak stations poor. reception on car radio fine.
If there is no FM Antenna connection you can try to move the power cord to different positions and see if you get a better signal. If not then move the unit closer to a window or try various locations that might have better reception.
Nov 21, 2013 | Sony ICF-CDK50 Clock Radio
1993 silverado no FM reception
That has been a problem with them for years allready that the FM Screws up on some of them, Just go out to a auto wrecker end get a different radio for it,It will cost you less , Then to have it repaired,
Dec 02, 2012 | Ac Delco AM-FM Radio Cassette
Poor radio reception in 2008 toyota avalon
I had the same exact problem. Toyota changed the Amolifier that improved sound quality but not the FM Reception.
THE HARNESSES CONNECTING ANTENNA TO RECEIVER (TWO OF THEM) HAD IAASUES. REPACING THEM FIXD THE ISSUE. FM RECEPTION EXCELLENT NOW !!!!!!!
Apr 11, 2012 | 2008 Toyota Avalon
Very poor FM receptio, and virtually no AM reception
The cascadia has an integrated AM-FM-WX, XM?, and CB antenna system, that is also prone to poor grounding. The best solution is to install aftermarket antenna systems for all of the equipment... I am driving a 2013 Cascadia with quite poor FM, and non existant AM, and WX reception. The XM works. I am afraid to hook up my CB to this, as it is pushing too much power, and is a sideband unit. I would like to hang the engineer by his/her toenails from the nearest tree for comming up with this garbage...
Mar 24, 2012 | Panasonic Car radio CD CQ-C1110GN CD...
I have a jc penney car stereo, am/fm cassette (service # 682-0392-00) that has very poor reception at its best. It is not a problem with the antenna, that has been changed and substituted with one from my...
You can purchase a in-line amplifier to boost radio signal, or just buy a new deck for less than $100 and get it installed. Great deals out there for decks below $100 installed. Try Best Buy or Fry's electronics.
Mar 15, 2010 | Car Audio & Video
FM reception for Sony ICF-CD513?
The electrical cord acts as an antennae for this radio. Uncoiling the cord will give the best reception for FM. Rotating the radio (and built in ferrite bar antennae) will give the best reception for AM listening.
Jan 31, 2010 | Sony ICF-CD513 Clock Radio
I own a 2005 jetta with a factory rady, cassette
you can try a AM/FM antenna booster if you know how to get to the back of the radio. Otherwise the radio ground needs to be checked out and the antenna ground would need to be tested to see if there was corrosion on the antenna base or the connector to the back of the radio. On some cars the antenna is located in bad area and they don't get the signal boost off of the cars ground plane The more reflective surface you have on the car the more radio waves will bounce back and increase signal strength. Also Depending on atmospheric conditions and skip conditions sun spots and other natural occurring things can cause poor reception. The signal booster is about $10.00 at any radio Shack or any auto parts store. Hope this helps.
Jan 22, 2010 | 2005 Volkswagen Jetta
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
