Question about Canon PIXMA MP830 All-In-One InkJet Printer
Printing color copies
I have a canon mp830 and the magenta ink ran out today and I didn't have a replacement. I put in an old cartrige that still had some ink in it and when it printed the reds didn't show up good. I went and bought a new magenta cartridge and put it in and now my copies both from computer or copies comes out with lines through the page. It looks like the reds are not coming through right. I tried see if the heads needed cleaning and tested it and they were fine. Do you have any idea what I can do to get it to print like it use too?
    Problem Solver:
  • 10 Answers
Check to see which cartridge you put in, photo magenta cartridges DO NOT work in the MP830. sounds silly but we see it all the time.
check to see if the short vertical black bar next to the magenta pattern looks ok, not brown or gray or streaky. if it is you may need a professional head flush, take the whole printer in for service.
Posted on Jun 03, 2008
Colored ink not printing correctly, lots of lines
You can try to use an other cartridge. if that won't fix your problem, you should send the printer back for repair
Apr 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Have replaced cartridge with one of my refilled cartridges in a canon PIXMA MP830, and am getting an alarm U071,that reads "more than one ink tank of the following color is installed". This is of course...
Printers have a mechanism to detect refilled cartridges. By default it does not accept refilled ones. But there's a work around. Have a set of two (preferably 3) cartridges , refill and cycle them. This way the printer wont be able to detect that you have inserted a refilled cartridge.
Dec 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My canonmp830 printer is not printing in black ink
**Repeat from previous post. Would not print black. I went through all the troubleshooting of cleaning the printhead several times. The Nozzle check (found under Printing Preferences/Maintenance tab) kept coming out without the PGBK section (Black) printed on it. All the colors printed. If your see any of the colors missing, it is probably the same problem---it needs the Print Head replaced.
Part # QY6-0061-010. I was able to find it at Canyon Computer Supplies in Phoenix, but you can also order them via the internet from multiple outlets. Mine cost $59.57 with tax...much cheaper than a new printer. The replacement is very easy...Canon has info on how to do it at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804#SupportDetailAct ...if the link doesn't get you right there, search MP830, Support & Service, then search print head & you should find it. Once you remove all the print cartriges (printer ON), the gray lever on the left side lifts up and releases the print head...which is the unit that houses all the print cartridges. I just put the new print head in, replaced all the ink cartridges, did a nozzle check...and it worked!! I love fixing things myself.
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Need to replace ink cartridge
http://reviews.cnet.com/multifunction-devices/pixma-mp830-office-all/4505-3181_7-31785803.html
Replacing the five ink tanks (cyan, yellow, magenta, black dye, and black pigment) is a simple task. The top of the printer flips up to reveal the ink tanks and the printheads, and by flipping a lever, you can pull out each tank individually. Being able to replace individual tanks is a boon, as you won't waste colors you use less frequently. Also, you won't need separate photo ink to print photos, which we appreciate. Canon ships the Pixma MP830 with full ink tanks. Replacement color and dye-based black ink tanks cost $14.25 apiece, while the pigment-based black ink tank costs $16.25. Canon estimates the cost per page for both black text and color text to be an inexpensive 2 cents.
May 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My mp830 will not print black only color
I had the same problem. I went through all the troubleshooting of cleaning the printhead several times. The Nozzle check (found under Printing Preferences/Maintenance tab) kept coming out without the PGBK section (Black) printed on it. All the colors printed. If your see any of the colors missing, it is probably the same problem---it needs the Print Head replaced.
Apr 07, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Alarm light is on and it won't print
I get the same error message. I pull out the yellow cartridge and put it back in. It will print a couple of times and I get the same message. Need a permanent fix.
Sep 08, 2008 | Canon PIXMA MP830 All-In-One InkJet...
My Canon PIXMA MP830 all-in-one is saying "the type of printhead is incorrect, install the correct printhead."
The cartrige is what holds the ink, the printhead is the device that puts the ink onto the paper.
So if your out of ink, then you need a new cartridge, if you have a new cartridge and you are having issues printing good quality, then you may need a new printhead.
you can get the ink here: http://printerinkcartridgesearch.printcountry.com/canon-pixma-mp830-ink-cartridges.htm
printhead is about 49.95
http://www.precisionroller.com/k_canon_pixma_mp830_print_head/m114d8577c104/
Hope this helps!
Brad Nelson
Mar 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
UO71 More than one ink tank of the follwoing color is installed/U140 The following ink tank cannot be recognized
Had the same error after replacing my black ink om my MP830.(UO71) I Put some Methylated Spirits on a cotton tip and gently cleaned the cartridge chip (allow it to air dry). This fixed my problem!
Aug 29, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830
Sometimes th cartrige chips have faults in them. I would take the ink cartridge back and I bet it fixes the problem
Feb 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
122 people viewed this question
old marine
old marine
