I have a belkin g wireless router, i am trying to set up my wireless. my problem is that i have an ntl modem but i cant connect the belkin wireless router because there is only one cable slot. same problem with the computer. how would i go about setting my wireless up?
sandrew
  • 2961 Answers
SOURCE: Belkins router not connecting to cable modem
You need to start from beginning. Clear all temp internet files and run this programme Start>Run ipconfig /flushdns and hit enter. Get into the routers settings(probably 192.168.2.1) and ensure in the Lan settings that 'DHCP Server' is on and wireless is enabled.(you might need to be connected by RJ45 lan cable first) If it's a 125mbps router change settings to 54mbps to try that speed first(especially as your wireless cards will be 54 mbps) look in Mac address Filtering is off. Look in the DHCP Client list and see if your pc's were allocated ip addresses, if so it should allow an internet connection. Go to both your pc's wireless cards properties and under TCP/IP properties ensure obtain ip address automatically is checked. Restart both pc's and the router, disconnect cable and try wirelessly
Posted on Mar 07, 2007
SOURCE: problems setting up Belkin wireless G+ mimo modem router/usb network adapter
I keep losing connection to internet. I have comcast rca modem with belkin wireless g router. HELP???
Posted on Dec 09, 2007
Neoklassic1
  • 70 Answers
SOURCE: Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Posted on Oct 14, 2008
  • 134 Answers
SOURCE: cant connect with the modem after cell phone mishap
Reconfigure your computer's software that was changed to make the phone work.
On the router, rtfm.
I doubt a cell phone could change the router's settings.
Posted on Feb 19, 2009
  • 50 Answers
SOURCE: modem light blinking and no internet in the
you have to unplug your cable modem before you connect the router. after you have connected the router you plug the power back on the cable modem then the router and you should be able to browse the net
Posted on Apr 21, 2009
I have a belkin router but i cant find the security code for it to use it on a different computer
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Sep 05, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
Whenever i start the vuze client i cannot surf the internet!!! I have a brand new Belkin N wireless modem router.
I also have this problem i.e whenever I start Vuze my Internent connetion is cut - I can't search Vuze and it takes 20 mins for my connection to be restored once I've closed Vuze - my ISP is Tiscali - anyone got any ideas?
Jan 10, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Cant get router to access internet
The easiest way to set up this router is to connect it via ethernet cable and then access the router with the default ip address and configure it from there
Dec 08, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
I have a belkin wireless g router model no f5d7230-4 and when i use it with my ntl broadband modem model 08004eu it causes my internet connection to keep going off,when i phone ntl they tell me to...
On and off at what rate? Every few seconds? Every few hours?
Does it cause the internet light on the modem to go off, or just the internet connection in the computer?
If you're using it wirelessly, what adapter in the computer? How far is the computer from the router?
(The router should work with any broadband modem.)
Sep 10, 2008 | Belkin Computers & Internet
Ntl:Home Compatibility
When you say the networking is fine, I assume that you can connect all wireless devices together and access the router menu on IP 192.168.2.2 (refer page 23)
Is it possible that when you connect the router to the modem that both are trying to assign an IP to the other?
My router is set to get it's WAN IP from the modem (it's a d-link though)
refer to the manual on page 28- try setting the WAN/internet setting to dynamic. You should leave the host name blank and not clone the MAC address.
MANUAL
Post back results and I will try to assist further if required
Jul 06, 2008 | Belkin Wireless-N Wireless Router with...
Belkin g4 router
Use WPA encryption . there will be an option in your router interface for this.
Jan 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Laptop
the internet cable should be connected to the "Internet" or "WAN" port on the router. Your PC should be connected to one of the regular ports on the back of the router and your laptop can be connected just like the pc, or it can connect wirelessly.
Then you should be able to see the internet from your laptop.
Jan 20, 2008 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
