Question about HP LaserJet 1012 Printer
Printer toner refilling
I need to refill my toner with my hand
My xerox machine getting error
Posted on Feb 18, 2009
Dear sir
how can refill the catrage with hand . with picture . the printer name 1020 pls help me
Posted on Nov 20, 2008
  • 26 Answers
You can fill it by yourself.
1. buy good qulity magnatic toner powder.
2. basic for oppening 12a toner is 2 SIDE SMALL PIN, YOU CAN EITHER PUT THESE PINS INSIDE THE TONER WITH THE HELP OF HAMMER AND NAIL.OR OTHER TRICK IS TO FIRST OPEN THE GEAR SIDE TWO screw BY PHILIPS SCREW DRIVER and pick up drum then with the help of l type sharp longe nail try to pull pins from inside to out side this by process you see you get two part of toner cartridge one is wast chamber another is main chamber smaller one is wast cleane it .
open the both side of main chamber by unscrewing 4 screw ond pour the toner power powder in that main hopper and do all the steps in vice versa. your toner is filled TAKE A TEST PAGE.
I can frovide you photos step by step mail me inkcity@rediffmail.com if neded
Posted on Jun 01, 2008
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
I have the 1522 printer. The toner ran out and I refilled using Chinese toner fron Deal Extreme. Black toner leaked out the right hand side of the toner cartridge messing up printing. I tried refilling...
it sounds like your priming station is full. you would have to spend some money to get it looked at this is not something you want to attempt your self.
Jul 30, 2017 | HP Office Equipment & Supplies
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 25, 2011 | Office Equipment & Supplies
Hp laserjet 1100 toner catridge refill?
Hi follow these steps..
1.Purchase a refill kit for your model of printer. It is important to purchase a refill kit designed for your specific model, since generic refill kits do not work well with HP printers. There are a number of places to buy these kits, but you must make sure you get the right kit for your printer model
2.Take the toner out of the printer and clean it carefully. Over time toner cartridges will accumulate paper dust, dried toner and other debris, and all of this must be cleaned away before the cartridge is refilled.
3.Flip the cover out of the way to expose the developer roller, then use a soft clean cloth to clean the roller. It is important to clean this roller before refilling the cartridge.
4.Make a small hole in the toner cartridge, using the instructions provided in the refill kit. It is important to follow the refill kit instructions carefully, since the toner refill process will vary from model to model.
5.Place the replacement toner in the hopper, then carefully pour it into the HP cartridge. Be careful not to spill any of the toner, and if you do spill the toner be sure to clean it up promptly. Reseal the hole you made after the cartridge has been refilled.
6.Sit the refilled HP cartridge on a clean flat surface and let it remain there for 20-30 minutes. Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
7.Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
Good Luck & cheers:-)
Jun 30, 2010 | HP LaserJet 1100 Printer
My Minolta Magicolor 2500W printer indicates that it is out of black toner. I have never changed the toner cartridge before and cannot find the instruction manual. (bought it almost 3 years ago...) Do I...
Firstly buy a black toner refill and a "CHIP". The chip is a small printed circuit carrying a chip, mounted on the top right hand corner of the toner cartridge held in by a small cross point screw. Remove the cartridge and looking at the right end you will see a round (About 3/4 inch dia) plastic bung. Lift this bung out and carefully refill the cartridge (The refill supplier will probably clarify this I am saying). Replace the bung, clean up all the messy dust and remove the old chip replacing it with the new one. Make sure you dont lose the little screw and insert it fully without over turning it. Thereafter all should be OK.
Dec 05, 2009 | Konica Minolta magicolor 2500W Laser...
How to refill toner HP Q6000A?
HP unfortunately uses a proprietary chip on their cartridges that renders normal refilling useless. You have a couple different options:
1) You can purchase an aftermarket toner cartridge.
2) You can get your hands dirty and ATTEMPT to do it yourself.
If you want to get your hands dirty, purchase a refilling kit, easily obtainable on eBay. See below link to an eBay search. The kit is made for the average person and includes the special reprogrammed chips for the refilled cartridges.
By far the easiest option is to just purchase a new aftermarket cartridge. However, with enough know-how, you can refill it yourself.
http://tinyurl.com/qlqf47
Jul 16, 2009 | HP 645A Magenta Toner Cartridge (C9733A)...
Brother 2140 toner light keep flashing and i just replace it with new toner
You need to look at the toner cartrage if it was a new or compatible cartrage bought to replace the old one the problem would not exist unless the printer is broken.(Or if the replacement has a missing or broken or miss postioned counting gear.)
Thier is a counting gear on the left side and on new or replacement cartarages it is in the 11 oclock postion when it is new. When the toner is all used it moves to the 3 oclock postion. What you need to do if you refilled the toner from a refill kit is to manually move the gear.
I believe thier is two ways to do this one buy a reset gear tool.
The other way that I do is to remove the three screws carefully that holds all the gears in place. Dont worry as it is just the cover and you can not really break the cartarage unless you strip the screws.
Once opened manually using your hand push firmly on the counting gear until you move it back to the 11 oclock postion. Then carefully reassemble the cover.
Once you place the cartrage back in the light will go off on its own and the toner counter will be reset.
3 don'ts
Do not try to only move the counter without refill you may get a few pages but this is bad for the printer
Do not leave any toner in the cartrage when refilling as this contaminates the toner and really shortens the refill life, try to get all the toner out as possible before refill.
Do not keep reshaking the cartrage and place it back in the printer, everytime you insert the cartarage the it can snag or be inserted a tiny bit wrong and break the gears in the printer. Do so in emergencys only, the rest of the time just refill the toner. $10 with delivery on ebay
Jul 09, 2009 | Brother HL 2140 Laser Printer
How do you refill hp cb436a
HP unfortunately uses a proprietary chip on their cartridges thatrenders normal refilling useless. You have a couple different options:
Ifyou want to get your hands dirty, purchase a refilling kit, easilyobtainable on eBay. See below link to an eBay search. The kit is madefor the average person and includes the special reprogrammed chips forthe refilled cartridges.
By far the easiest option is to justpurchase a new aftermarket cartridge. However, with enough know-how,you can refill it yourself.
http://tinyurl.com/pedczh
Jul 06, 2009 | HP 645A Magenta Toner Cartridge (C9733A)...
Refill Toner Cartridge for Laser Printer
Nobody has a clue how to refill a laser cartridge with ink. :)))
OK< just kidding, here it is:
First of all, laser-cartridges have toner (a fine black powder) and not ink.
Second: There are 2 methods to refill a laser cartridge: dismounting it to get to the toner chamber (involves a lot of tehnical skill) or the melt-and-pour method (see here http://www.urefilltoner.co.uk/), but you need the melting device.
But because from your question i see you dont know a thing about refilling, better go to a refill center.
Feb 14, 2008 | HP LaserJet 1012 Printer
HP LaserJet 1012 Printer Logo
140 people viewed this question
Seeker5211
Seeker5211
