Question about Xerox 5305 Copier
Hello, after i was moving to another Town, i unpacked my Xerox 5305 and tried to copy some documents. The Problem was, that i get an H4 error. It was for the first time, and nothing happens - - no copies are done. The Internet "says", that is an fuser problem. How can i fix this problem. Thank you for any help. best regards Olaf Wöhlk
  • 53 Answers
SOURCE: xerox 5305 copier excess toner
sounds like faulty drum cleaning blade,which is usually contained in the replacement drum module.I would be inclined to take the drum unit back where you got it (unless you replaced it with a second-hand one) 99% certain the problem is contained in that module
Posted on Feb 27, 2008
micromaster
  • 3614 Answers
SOURCE: My Xerox B/W Copier XC 1044
look for any paper jam, and inspect the toner
Posted on Jun 09, 2008
  • 2072 Answers
SOURCE: Xerox copycentre c20 fades out on one side of copies
If the scanner will not move you it is jammes on the scanner lock latch. Shut the machine off. Look up in the ares where the copies come out, between the paper tray and the scanner. Look under there, you will see a green latch, about 2 inches long and maybe a half an inch wide. Its the only green item on the bottom of the scanner. Push that latch in toward the back of the machine, then pull it out toward yourself until you feel it snap into place.
That can easily be moved when reaching in to take your copies out of the tray. You can put a piece of tape over it to keep it in place. Orrrrrrr, if you want. when you lift the document feeder, there is that 1 inch strip of glass held in with 2 phillips screws. Remove those screws, take that **** glass out, DO THIS WITH THE MACHINE OFF by the way.... you will see that green latch inside on the bottom. You may have to slide the scanner head out of the way a little bit. When you look at the green latch, you will see 2 plastic clips on the sides, just compress those tabs and pop the latch out of the bottom. Make sure you note the direction you take it out, because you want to flip it around . There is a tab on the latch that will catch better when it it flipped around, You can also just break off the hooked part of the plastic and snap it back in.
You only need that latch for shipping or if your going to send the machine on a ship across the ocean soon. I sort of doubt your going to do that .... Its just a shipping latch, no big deal to modify it .
That should resolve your problem. If not let me know. There are other things we can try,but if the scanner is not moving, there is a 99.999999999999999999999999999999999999999999 percent chance the latch is just out of position.
Posted on Jan 13, 2009
Arius
  • 446 Answers
SOURCE: Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Posted on Jul 28, 2009
  • 24 Answers
SOURCE: Where to put fuser oil in a xerox 5624 copier
I don't believe this machine uses Fuser oil. I bet it was picked up from a sight that had other machines and the oil was just put inside the machine as it was being wheeled away.
Posted on Sep 09, 2009
Testimonial: "Thank you, this is the most common sense answer that I have heard from the USA to India!"
Xerox 5305 does not feed paper
Those old babies just keep going! You need some serious TLC. And, a feed tire no doubt.
Jan 29, 2011 | Xerox 5305 Copier
Error code L8 on XEROX model 5305
That indicates the main board has not sensed the exposure lamps coming on. Those are solder in lamps, I believe there are 6 or 7 on the array.
Mar 01, 2010 | Xerox Office Equipment & Supplies
Xerox model # XC1040 flashes H4 when turned on will not make copies ? code
H4 is a fuser error code. it basically means that the fuser is heating up. from what i can see the fuser lamp alone will be about $60.00. that would be the best case scenario if the rest of the fuser parts are ok. the upper fuser roller is 135.00 and lower 144.00.
Oct 16, 2009 | Xerox Office Equipment & Supplies
My xerox 5201 copier is making black copies. I
Xerox Copy Drum Cartridge 13R83 / 6R737 (20000 Page Yield)
Xerox brand - works in Xerox XC 355 XC 356 5201 5203 5205 5210 5220 5222 5305 5306 PRice is 135.00.. Post response if you want link to site. This will cure your grounding problem. You Cannot fix it, It is a consumable item and has no serviceable parts
Apr 03, 2009 | Xerox Office Equipment & Supplies
Error H-4
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and sometimes the temp sensor jammed.
Only when the problem is a jammed temp sensor or a jammed control board you can reset the machine by doing a reset.
You try reset from simulation mode by following procedure below:
Clear key >>Interrupt key >> "0" key >> Interrupt key >> Main code >>Start key >> Sub code >> Start key
If the error remains, that means that the fuser is really bad and must be replaced.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Mar 01, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox Pro16fx - H4 Error Massage after power outtage
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=473,E=0000000001213816584,K=3906,Sxi=8,Case=obj(6116)
Feb 02, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox Workcentre Pro16fx - H4 error code after power outtage
You shut the machine off then on, Press Clear, auto,clear , auto, then when the lights go out, program it as if you were running 14 copies. press start and that should reset it.
Thats the redish pink clear button and the auto exposure button, Clear, Auto , clear auto, and the display goes blank , enter 14 and start. Dont ask me why I repeated that LOL
Feb 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
I found it in basement
the 5305 was a portable copier and the paper tray attached to the platen cover (glass cover). It may be there. The device will not work without a paper tray. If it's been in the basement, you may need to make sure there are cartridges in it too before attempting to power it on. If there is not a toner cartridge, the device will not power on.
Jul 29, 2008 | Xerox 5305 Copier
Xerox 5305 copier excess toner
Feb 27, 2008 | Xerox 5305 Copier
Xerox printer xd100
H4 is a power failure code. To reset the error please press in the following order: CLR - AUTO - CLR - AUTO (this puts the unit in tech mode). Enter 14 (as if asking for 14 copies) Press "PRINT" Your unit should reset itself and start working.
Sep 24, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox 5305 Copier Logo
47 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
