Question about Insignia NSC3113 Car CD MP3 Player
RECIEVER LIGHTS ARE DIM - Insignia NSC3113 Car CD MP3 Player
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
Light is dim
Why do my lights in my house dim when I use the Microwave or dryer ...
https://answers.yahoo.com/question/index?qid...
Jan 16, 2010 - I dont run a lot electricity. It seems that if I run something like themicrowave any lights that are on dim. Is something wrong here? I dont see why ... Light on microwave too dim to read -- can it be fixed? ' Yahoo ...
May 11, 2014
My lights dim when I turn on a powerful electrical device ...
Dec 31, 2007
Why causes all the lights to dim and then brighten repeatedly ...
Dec 28, 2006
More results from answers.yahoo.com
Dimming Microwave Light - Breville Support
brevilleusasupport.com/bmo734xl/dimming-microwave-light/
Apr 10, 2014 - Occasionally, when using power settings that are lower then the normal 100% cooking power, the light inside the microwave cavity may dim.
Gmc envoy bright lights work dim lights will not work
Your circuit lights may be bright or dim according to how your electrical system was set up. It may dim when lights are off and get bright when lights are on. ------------------------------------------------------------------------------------------
Car Diagnostic Tools
Nov 24, 2012 | Buick LaCrosse Cars & Trucks
Brakes short lights
You need to get you alternator tested, it sounds like the current output is too low.
Mar 11, 2012 | 2005 GMC Safari
TX-DS656 - No display, still works.
Mine goes out sometimes, if I go to the reciever and hit the "Display" butoon, the display lights up dim, at same time, I hit the " Dimmer" botton on remote and display works for about 1-2 weeks. Don't know what is cuasing it, but that got the dispaly to work. Can deal with that I guess.
Sep 02, 2010 | Onkyo TX-DS656 Receiver
Light and fan go on with the wall switch. But I cannot turn out or dim the lights with the remote. I can work the fan. I changed the batteries in the remote. Could it be the reciever for the lighjts. Where...
Dear rwk,
youe remote unit is OK as I can understand from your feed back. The problem lies with you the light control power device. The Triac of the light controller is shorted. It has to be replaced with a new one. If the wattage of the lights is within 250W, you can use a triac of type no BT136. It is located in the wall remote receiver unit.
Thanks
-Mitra
Sep 25, 2009 | Hunter Ceiling Fan Light Remote Control
I am unable to turn the light off using the fan remote, the fan itself using the remote works fine. the only thing I can get the lights to do with the remote is dim.
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at home depot. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jerry_612d8419f8984578
Aug 31, 2009 | Hunter 52" Ceiling Fan With Light And...
Lights go out
Dimmer switch is going bad. If you rapid fire the switch they will switch from bright to dim or dim to bright. replace the colum switch.
Feb 08, 2009 | 2001 Dodge Ram 3500 Truck
Vsx-d506s problem
It may be a PROTECT MODE. Check is your other equipment properly connected to receiver.
Oct 09, 2007 | Pioneer VSX-D506S Receiver
Door won't go down
Yes ,your path may be clear and you might have two indicator lights lit,but remember that theese sensors are called a sender and a reciever,the sender send,s a signal to the reciever to let it know that alls clear and their are no obsructions , but i can tell you from experience that if your sensor has the slightest fliker it will not allow the door to come down as a safety feature that was incorporated in all machines by law from 13 years ago, First thing you want to do is find out which sensor is the reciever and this is very easy ,Just put your hand in front of one of the camera,s ....The one sensor that,s light goes out is the receiver, Thats because it is not receiving a signal ! Now I want you to make shure it is straight in it,s holder,aiming directly accross from the other sensor! Next go to the sender ,This beam is the crucial one and must be directly pointed at the reciever, notice the light on the sensor it is always solid and will not go out ,Next i want you to go back to the reciever and loosen up the wingnut that holds the sensor in the bracket , as you move the sensor up to down and left to right notice the light on the receiver become dim and bright and flicker as you move it from the direct path of the sender , this is exactly what i want you to adjust to it,s brightest light possible , after you have tightened it back up go over to the wallpad or doorbell that operates the door and see if your problem has now dissapeared , Thank you for letting me try to help you and hopefully we fixed together Sincerely Glenn Mayer
Aug 20, 2007 | Chamberlain Powerdrive PD422D 1/2 HP...
Insignia NSC3113 Car CD MP3 Player Logo
74 people viewed this question
Top Insignia Car Audio & Video Experts
Mark Skinner
Frank Mangiapane
Level 1 Expert
Are you an Insignia Car Audio and Video Expert? Answer questions, earn points and help others
