Question about KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator
Kitchenaid KBFS20EVMS. A small plastic dowel that fits into the lid to the meat/cheese tray that spans the bottom of the fridge area has broken off. The large piece that it broke off of is attached to the lower right side of the fridge. Can this be replaced? How would I find out the part number and how to replace. thanks caryl
  • 833 Answers
SOURCE: Kitchenaid side by side refrigerator
First thing I would check...is this unit frosting up? Turn it off for two days...with the doors open...to defrost completely. Clean out the condenser coils with a brush. Inspect and clean any gaskets not sealing. When restarting...open up the back panel and check the compressor. It is that big black thing. Find and clean off the largest pipe. Watch the pipe...It will frost initially on startup. Does the frost remain after 5 minutes or turn to ice, water or dry out? If still frosty, you are low on gas. If other conditions, then you either are opening the door too often, those gaskets are damaged or you have defrost issues.
Posted on Dec 21, 2007
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: Mullion strip between doors gets too hot!
Up to 125 degrees on the mullion heater is normal.
Posted on Jun 16, 2009
erpaalai
  • 999 Answers
SOURCE: How do I replace the Icemaker Ice Stripper Arm on
Remove the IM assembly from the freezer. Take off the front cover and there will be 3 screws to remove the module. Behind that are 2 screws , loosen them untill you can get the stripper arm out.
Eric
Posted on Jun 19, 2009
  • 949 Answers
SOURCE: How to change the water filter on my Kitchenaid Superba fridge?
The details are on page 6 of this manual or I have pasted them below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202306982.pdf
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the protective covers from the O-rings.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See “Water and Ice Dispensers.”
Posted on Apr 18, 2010
Piece of lid broke off
Sand the area on bottom of piece along with areas surrounding the broken piece. Get another small piece of plastic that is large enough to cover the broken piece and adjacent areas and apply the glue to that using a good epoxy for adhesion. Let it set up and it will hold - trust me.
Sep 27, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
Fridge leaks from freezer
Sounds as drain is plugged. Remove rear cover in the freezer and check drain . Also clean drain pipe in the fridge at the top part and clear drain tube
Aug 26, 2014 | KitchenAid Kitchen Aid 19.8 Cu. Ft....
What causes food to freeze in the bottom of the refrigerator & meat & cheese tray
See if there is a temperature setting on the side of the drawer. Mine has a small lever that opens a hole to the freezer to keep that drawer colder. If it's opened too far the food will freeze.
Jul 26, 2014 | Jenn-Air Refrigerators
Freezer door leaking
I thought my leak was also coming from a line but nope - it's the black drain grommet that fits over the drain located just above the compressor in the back bottom of the unit. I had to use a blow dryer inside the freezer section to unthought the ice that was behind the freezer back wall. No need to take the freezer inside back plate off just use a blow dryer to melt the ice where the grille is located inside the freezer. You do have to take the back plate off where the water lines go into the bottom of the fridge. Once the back plate is off you then disconnect a yello and Orange plug that goes to the water line selinoid valve. Then prop up the back plate with the water lines still attached so you can access the black grommet on the drain. You must also disconnect the black drain tube from the water tray. Be careful not to break it as there is a small push clip that must be pushed in while you pull up. Once it's off then take the black grommet off of the drain that is just above the compressor. Mine was plugged with lint and sticky - wash throughly and then take a small pick or screw driver and insert it in the drain - once I did this about 2 cups of water came out so be prepared with a cup to keep it off the wires right below the drain. Clean up the water in the freezer and then reverse wha thou took off and then plug the fridge back in - you just saved $150 on appliance house call. Bad design for a high end fridge - my sears in the garage is 20 years old and not one problem. Cold beer on hand. Hope this helps!
Aug 13, 2012 | KitchenAid KBFS20EVMS 36" french door...
Can't reinstall meat drawer after cleaning
I think you'll have to move the fridge till you have the clearance to open the door all the way. Those drawers have to go straight in.
Mar 11, 2010 | Amana ABB1927DE Bottom Freezer...
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
I have a tefal TT550015 toast 'n' Egg and have no instructions on how to use it. Please advise
To use the egg side only, fill the measuring cup with the correct amounts of water. (One side is for boiled eggs, one is for poached eggs.) Pour the water into the basin at the bottom. For boiled- Place 1-4 eggs in the tray with the four holes. Use the sharp thing at the bottom of the measuring cup to pierce the egg shell. Place the lid over top, and hit the 'egg' button. When the light on the button goes out, remove the lid. For poached, grease the pan. Spray/ butter, whatever. DO NOT rely on the non-stick. The thick black tray for boiling eggs goes on first. With the egg in the greased pan (scrambled or whole) place the pan into the unit. There are four plastic pieces in the boiling tray to show you where it goes, the handles aligned. The round tray, with the square holes in it, can be used to warm pre-cooked meat.This is optional, and that tray goes on top. Place the lid over the top, and press 'egg'.
WARNING: this cooks by steam, and any remainder can cause burns. Be careful when removing the lid. Same goes for the product. The boiled eggs should not be touched directly.
To make an egg sandwich, load the egg side and the bread/english muffin/bagel into the toaster. Press the 'egg/toast' button BEFORE starting the toaster. The toaster will start on a timer so that the egg and toast will be done at the same time. When the toast pops up, you are good to go.
Note: there should be no water afterwards, maybe a little oil if you cooked meat. Hard water residue is easily removed with vineger and a paper towel.
Dec 02, 2008 | Back to Basics TEM-500 Egg & Muffin...
Broken rear stationmary support on mat/cheese drawer
yep, order part number 61005337 and part 67764-1 about 2 bucks each and it will fix ya
Apr 23, 2008 | Maytag MZD2766GES Side by Side...
Fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Mar 24, 2008 | Refrigerators
KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator Logo
125 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
