I turn on the computer and it will not go off the first page and will not let me use the keyboard
    Problem Solver:
  • 11 Answers
I am assuning that by the first page u mean the BIOS startup screen. if that is the case then simply disconnect all the devices connected to your computer (keyboard, mouse, printer, web camera, etc)and start the computer . if it goes through then reconnect the devices 1-by-1 and restart . this will let you know which device is failing.
lemme know if it helps
Posted on Jun 01, 2008
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Needtogetaroundcomputerkey
    You can adjust turn on or adjust settings for these features on the Use the computer without the mouse or keyboard page in the Ease of Access Center. Open the Use the computer without a mouse or keyboard page by clicking the Start button , clicking Control Panel, clicking Ease of Access, clicking Ease of Access Center, and then clicking Use the computer without a mouse or keyboard.
    Select the options that you want to use:
    Use On-Screen Keyboard. This option sets On-Screen Keyboard to run when you log on to Windows. On-Screen Keyboard displays a visual keyboard with all the standard keys. You can select keys using the mouse or another pointing device, or you can use keys on the standard keyboard. For more information about using On-Screen Keyboard, see Type without using the keyboard (On-Screen Keyboard).
    Use Speech Recognition. The option allows you to control the computer with your voice. With a microphone, you can speak commands that the computer will understand and respond to, as well as dictate text.
    May 11, 2015 | Computers & Internet
    I forgot my bios password compaq presario 900 password bios cen you help my
    Before removing the RTC battery, follow these steps:1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn thecomputer on, and then shut it down through the operating system.2. Disconnect all external devices connected to the computer.3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet andthen unplugging the AC adapter from the computer.4. Remove the battery (see Battery on page 34).5. Remove the following components:a. Hard drive (see Hard drive on page 37)b. Optical drive (see Optical drive on page 44)c. Switch cover and keyboard (see Switch cover and keyboard on page 46)d. Display assembly (see Display assembly on page 50)e. Top cover (see Top cover on page 55)f. Fan (see Fan on page 58)g. System board (see System board on page 60)Remove the RTC battery:1. Turn the system board upside down, with the audio connectors toward you.
    found here: http://h10032.www1.hp.com/ctg/Manual/c01295803.pdf page 65. you'll have to pull the battery for 5 minutes and then reinstall and all cmos passwords should be cleared! good luck
    Jan 27, 2012 | Compaq Presario Notebook
    Ways to take care of yaour keyboard
    Things You'll Need
    • Computer Keyboard
    • Cotton Swab
    • Isopropyl alcohol
      • Before doing any type of cleaning make sure to turn off your computer and disconnect the computer keyboard from it.
      • Once the keyboard is unhooked, turn it upside down and grab the can of compressed air. With the keyboard still upside down, tap it and watch all of the dust and grime fall out. Repeat this step 1 or 2 more times until nothing falls from the keyboard when you turn it upside down.
      • Take the cotton swab and dip it into the alcohol before cleaning the sides of the keyboard
  • If you want a more thorough cleaning, remove all of the keys from the keyboard and take a moist cloth and wipe away the dust. Also use the can of compressed air to vanish away grime particles.
  • Never use a wet towel on your computer keyboard
  • Turn off your computer and then unplug and reseat your keyboard. Occasionally computers will experience glitches that prevent drivers and software from loading correctly. Restarting your computer and plugging your keyboard back in will often solve the problem. If not, View your keyboard's status in the Device Manager. To access the Device Manager, open the Windows Control Panel and click on "System and Maintenance." Scroll down to the third section from the bottom and click on "Device Manager." In the menu bar at the top of the Device Manager window, press the button called "Scan for hardware changes." Windows will now scan your computer for any new or malfunctioning hardware. Once the page refreshes, go down the list of devices and click on "Keyboards." Right-click on your keyboard and select "Properties." A new screen will then pop up to tell you whether Windows thinks the device is working properly. If the system indicates the keyboard is not working properly but doesn't give you instructions on how to fix the problem, .
  • Visit your keyboard manufacturer's website and view the support or troubleshooting sections. Find the "Search Help" (or similarly named) box and enter your keyboard model number (this can be found on the bottom of your keyboard on a sticker or engraved in the plastic).
  • Jun 12, 2011 | Acer NSK8458AN Keyboard
    My lenovo x61 show a lock hence does not boot. I had set up a bios password which i can't remember.could u have an idea?
    For a desktop computer:
    Depending on the motherboard of the computer in question you can:
    • Locate and change the position of a jumper that will clear the BIOS settings.
    • Unplug the machine and pull out the battery that maintains the BIOS settings in RAM.
    For the Lenovo x61 and other laptops:
    Follow this link to see the laptop manual: http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/42x3550_04.pdf
    1. Turn off the computer.
    2. Remove the battery pack. (See "1010 Battery pack" on page 60 of the above link.
    3. Remove the backup battery. (For how to remove the backup battery, see "1140 Backup battery" on page 82 and page 65 of the above link).
    3a. You must remove the keyboard and battery pack to access backup battery.
    3b. Remove 4 screws with keyboard icon to remove keyboard.
    3c. Gently push the keyboard forward.
    3d. Then lift up the keyboard slightly.
    3e. Detach the keyboard connector.
    3f. Remove keyboard.
    3g. Disconnect the backup battery.
    4. Turn on the computer and wait until the POST ends.
    After the POST ends, the password prompt should not appear. The POP has been removed.
    5. Reinstall the backup battery and the battery pack and the keyboard.
    Good luck and thanks for using FixYa.
    Mar 03, 2011 | Computers & Internet
    I cant get my keyboard to connect to the computer. everytime i turn it on it says it cant identifie with the usb connection, but the keyboard does turn on so it is reading something
    Hi !Have you try to install the latest driver?Go to the following page, Select you product and operating system, download and follow the instructions.
    http://www.m-audio.com/index.php?do=support&tab=driver
    Hope i helped,omerk.
    Feb 27, 2011 | M-Audio US85100 Keyboard
    The wireless keyboard and mouse are not working.
    • Check to ensure that the wireless receiver is plugged into your computer. Press the "Connect" button on the bottom of the receiver to attempt reconnecting your mouse and keyboard to the computer. If your mouse and keyboard use Bluetooth, ensure that your computer's Bluetooth is active and detects the mouse and keyboard.
    • Check to see if the keyboard and mouse are turned on. If the power indicator lights on the keyboard and mouse are not green, press the "Power" button to turn the keyboard and mouse on.
    • Check the batteries of the mouse and keyboard. If the batteries are dead, replace them with fresh batteries and reconnect the mouse and keyboard to the computer by pressing the "Connect" button on the bottom of the wireless receiver attached to the computer. If your mouse and keyboard use rechargeable batteries, let the batteries recharge before using the device again.
    • Uninstall and reinstall your wireless keyboard and mouse drivers. Sometimes, the Logitech drivers are at fault for a bad connection. Use the Control Panel to uninstall the old drivers, then visit the Logitech website and install the latest drivers for your keyboard and mouse.
    • Search the Logitech Support Database. If your keyboard and mouse are still failing to function properly, visit the Logitech Support website and browse the support page for your product for specific solutions.
    Feb 04, 2011 | Logitech Computers & Internet
    Im trying to put in my power button on my hp 60 230 us notebook pc
    Power button board 496830-001
    1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on,
    3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then
    4. Remove the battery (see "Battery" on page 4-7).
    5. Disconnect the wireless antenna cables from the WLAN module (see "WLAN module" on page 4-15).
    6. Remove the keyboard (see "Keyboard" on page 4-17).
    7. Remove the keyboard cover (see "Keyboard cover" on page 4-20).
    Remove the power button board:
    1. Remove the two Phillips PM2.0x4.0 screws 1 that secure the power button board to the keyboard cover.
    2. Remove the power button board 2.
    Here is the service manual: See page 4-22
    http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
    Click on this link or copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 01, 2011 | HP Computers & Internet
    How to replace keyboard for HP Pavilion DV2700?
    Below is the link to the service manual and below that are the steps to the procedure. If want, open the manual and follow along with the procedures below, they are linked and cooincide with one another. The manual is free to copy, print and use.
    http://h10032.www1.hp.com/ctg/Manual/c01295820.pdf
    4. Remove the battery (see Battery on page 56).
    Remove the keyboard:
    1. Turn the computer upside down, with the front toward you.
    2. Remove the three Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
    3. Turn the computer display-side up, with the front toward you.
    4. Open the computer as far as possible.
    5. Lift the rear edge of the keyboard (1) until it rests at an angle.
    6. Release the keyboard (2) by sliding it back to disengage the tabs on the front edge of the keyboard
    from the top cover.
    76 Chapter 4 Removal and replacement procedures
    7. Lift the rear edge of the keyboard (3) and swing it forward until it rests on the palm rest.
    8. Release the zero insertion force (ZIF) connector (1) to which the keyboard cable is attached and
    disconnect the keyboard cable (2) from the system board.
    9. Remove the keyboard.
    Reverse this procedure to install the keyboard.
    Nov 05, 2009 | Computers & Internet
    1 "how do i program the Web/Home button at
    you go to your setting of your computer and then select network button and find the network home page and you just type your favorite home page then restart your computer.. after you restart you computer, click the browser button to start on your computer... and see your home page is just change..
    May 09, 2009 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
    Computers & Internet Logo
    35 people viewed this question
    David Payne
    David Payne
