Question about Kenmore 85871 Electric Dryer
Our dryer is not heating up. Is there anything I can check before I call in for a repair? Thank you
  • Kenmore Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
I am getting e4a on my gas dryer
Good Afternoon Friend, this is Z. Thank you for your post!
Typically error code E4A indicates that your Frigidaire dryer is experiencing a program timeout fault or max time has exceeded for that cycle. A professional normally checks for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closed with solid door, faulty connection in moisture sensor bar circuit. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your dryer. Hope this helps!
Aug 07, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Dryer not heating
Hi
There are various factors as to why an electric dryer is not heating. A burnt out heating element, A blown thermal fuse. Even wiring connections. Please check the bellow links to troubleshoot your problem:-
http://www.repairclinic.com/Dryer-Troubleshooting?red=Dryer-Repair-Help#theresnoheat_electric
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Kenmore 62602 Electric Dryer
Hi, any helpful tips on troubleshooting and possibility repairing a LG DLE7177 RM Dryer from a layman's point to help financially. I am not able to afford a Technician at this time and like to know if...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | LG Dryers
My worldpool dryer truns but will not heat up??
Thank you for contacting Fixya.com.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Check the thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) that is mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation.
Please check the bellow link to have an in-depth knowledge as to when the dryer wont heat up...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have any further query.
Have a nice day.
Nov 29, 2010 | Whirlpool Dryers
My dryer has stopped heating and has started to lightly squeak. What's wrong?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
heatman101
Aug 31, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Our Kenmore Dryer of many years has Only cold air coming from it for drying purposes. Is their anything we can do ourselves to repair it? Thank you.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 05, 2010 | Kenmore Dryers
Replaced heating element and it still wont fire up
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 02, 2010 | GE DVL223EBWW Electric Dryer
My dryer is not heating up is there anything I should check before I call a repair person
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 04, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore dryer not heating
DID YOU CHANGE THE HIGH TEMP THERMOSTAT ALSO?MIKE
Mar 19, 2009 | Kenmore Dryers
Kenmore 85871 Electric Dryer Logo
62 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
