THE COPIER ON DESIPLAY CALL FOR SERVICE H4-00
  • 1,110 Answers
What model of copier are you asking about? The H4 code means your machine is not heating properly, but in order to give you a reset or a solution we need the model number.
Thanks,
WheatlandServices
Posted on Oct 12, 2010
How can I solve the copier showing service code c467?
You are not supposed to do anything on the copier. Just call the service desk, tell them what code you read.
Jun 04, 2014 | Toshiba E-studio 3510c Color Copier....
What is the service code
There is no service code.
To reset the copier press and hold 0,8. button and switch on the copier.
enter 690 press start button
enter 2 and press enter key on touch screen.
once the reboot massage apears switch off the copier and switch on.
Mar 29, 2014 | Toshiba E-studio 230 Multifunction Copier
H5-01 copier service code
you can not reset
need to take technical service
Sep 24, 2013 | Office Equipment & Supplies
Our Sharp ARM455N Copier shows "Maintenance
this is message that the copier did certain amount of copies and it needs to be cleaned and ispected. The purpose of preventive maintenace is to stop or reduce problems before they occure. In most cases they occure when you need the copier urgently.
This can be reseted in simulation mode, but I recommend to get service technician to service the copier.
If you want to reset the alarm leave the email and I'll send you the service manual.
Sep 09, 2011 | Sharp AR-M455N Copier
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Service code C0B52
1. Turn off copier 2.Disconect finisher cable 3.Turn on the copier . If it works properly turn it off &reconnect finisher cable then turn it on .
Apr 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Service manual
u can try here put your query here like need service manual copier Toshiba e studio 353 and search u get best result for  tosiba service  manual //technologysearchengine.org/
Apr 04, 2009 | Toshiba e-Studio 350 Copier
Can you produce me a copy of toshiba 2860 service manual?
Copier service manuals can be purchased from www.justmanuals.com.They are a pay site but seem to be reasonable.Good Luck
Apr 02, 2009 | Toshiba 2860 Copier
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Jan 08, 2008 | Canon imageRUNNER 5020 Copier
127 people viewed this question
k24674
jasbo
jasbo
