Question about Jenn-Air Electric Double Oven
The ovens no longer get up to temperature. And if you do get it to a temperature, it does't stay at that tem. It just continues to get cooler.
  • Jenn-Air Master
  • 43,501 Answers
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Posted on Oct 12, 2010
Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
Oct 16, 2017 | Bosch Ovens
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
I replaced the element in my belling double oven, it wored for a while but was very hot thought it was the thermostat, now it has no heat at all no light but the fan still works.The top oven and gril has...
Hi.
Replace the temperature probe located in the oven cavity. The probe was initially shorted. That caused temperature runaway with the oven getting too hot. After a while the shorted sensor blew completely staying open all the time. That is resulting in no heat.
If the temperature sensor has already been replaced, then problem is either wiring or oven electronic control. Wiring harness is tested checking continuity between different points.
Regards.
Ginko
Jul 17, 2011 | Belling XOU592 / XOU593 Electric Double...
Hi got a NEFF B1691 oven. Thing is the oven light, element and fan keep switching off during cooking is this correct functionality - if not what could be wrong? The temperature display remains functioning...
There does seem to be a fault, as the fan should run continuously even when the element goes off at the required temperature setting, and the light should atay on as well.
It suggests to me that there is a fault with the oven thermostat, or it is wired incorrectly.
Dec 21, 2010 | Neff B1691 Single circotherm super...
Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 14, 2010 | Amana Ovens
My hotpoint ew61 double oven doesnt come up to
If it is heating, but not getting hot enough, then it is possible the thermostat is cutting the element off too soon, in this event, you will need to replace the thermostat.
If it is not heating at all , then the element is probably faulty.
Please rate my solution.
Thanks.
Nov 14, 2009 | Ovens
I have a magic chef range/oven. For the last few months, it has taken longer and longer for the oven to heat up to temp. Now it won't get more than 90 degrees or so. What is the problem??
Turn off the power to the range. Remove the bake element from inside the oven. Be careful not to let the wires go back into the oven cavity. Take a volt/ohm meter set for ohms or continuity and test the bake element leads. If you get no reading replace the element. If you do get a reading,replace the temperature sensor in the oven.
Oct 08, 2009 | Magic Chef Ovens
Dacor Oven - convection fan stays on while on "bake" setting
Question: does the unit appear to hold the correct temperature? Most convection units only turn the heating elements on and off...not the fan. If the unit is reporting operating temp and then taking other direction...and it is cooking right...you're done.
Nov 14, 2007 | Dacor ECS127 Epicure Stainless Steel...
Jenn-Air Electric Double Oven Logo
150 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
