Question about Ovens
OVEN IS NOT HEATING UP. JUST USED IT 3 DAYS AGO & WHEN I WENT TO WARM IT UP TO USE LAST NIGHT...NOTHING.
  • Ovens Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Oct 12, 2010
I used the self cleaner 2 days ago and now the oven will not heat. It warms only to 80-90?
Rhonda, its possible the heat sensor / probe may need to be changed, it is a small copper or brass wire with a small probe, that hangs on the upper portion of back wall in oven.
Mar 11, 2016 | Ovens
Oven not working
you would have to check the element for continuity. Also the oven sensor could be suspect and should ohm out at 1180 at room temp. if both those are ok then main control is probable. without schematic it would be hard to say for sure..there may even be a safety fuse blown.
Jun 13, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
E2 F6 ??? What the? Oven came with house, no manual.
Your oven temperature sensor has failed(e-2) as well as your electronic control board(f-6). The oven temp sensor, electronic control board and the touchpad must be replaced . Approximate cost of parts is $500.00. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Jun 12, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven light
Hi there it's possible that you are using an incorrect bulb in your oven....ensure on purchasing relacements that these are OVEN Bulbs (these are special bulb to operate at high temperature) ensure that the bulbs are screwed correctly and firmly into the holders and the glass cap is correctly fitted and secure.....
regards Sir Galahad
Mar 10, 2009 | DCS Large Appliances Built-In Ovens...
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
Oven not heating
you could have lost one of your 120v leads to the machine. that could cause it to work only half way. go turn the breaker off and then turn it back on and see if that corrects the problem.
Dec 07, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Oven seems to be going crazy
You may have a problem with the keypad. I suggest that you review my solution at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with over 1470 folks and most report success.
If it works for you please let me know at the following site:
hutchipop@yahoo.com
Good Luck
Dec 13, 2007 | GE Profile JKP18 Electric Single Oven
Lower oven won't heat
it must be thermostat in bottom oven
Nov 29, 2007 | Frigidaire PLEB27T9DC Electric Double Oven
Ovens Logo
73 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
