I have model # ESP 7250, with a red error code message 6202
  • 13,433 Answers
Hello..
the error message "Scanner motor failed" (error code 6202)
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Wait 30 seconds to allow the printer to reset.
  4. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer has powered up, the message "Printer access door open" will appear.
  5. Close the printer access door.
If the error continues, contact Kodak.
The scanner motor will most likely need to be replaced, if you are outside of warranty contact kodak and see if it is worth the repair.
Posted on Oct 12, 2010
I have an error msg E161-403E on an IPF 655 and cannot remove it to access the settings menu.
my kodak esp 7250 printer will go through all cycles but will not print anything. it does not give any errow codes or messages.
Sep 14, 2013 | Office Equipment & Supplies
Error code 6202
Thank you for contacting FixYa printer support. Error: "Printer error" (6202) Published 08/25/2010 11:38 AM ' Updated 05/20/2011 09:04 AM ' Answer ID 1247
How do I resolve the error message "Printer error" (error code 6202)?
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
When the printer is ready (no error message), upgrade the firmware for your printer:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
If the error continues and you cannot upgrade the firmware, contact Kodak Technical Support.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 11, 2011 | Office Equipment & Supplies
On a 7250 have error code 6202, having..
When the printer is ready (no error message), upgrade the firmware.
If the error continues and you cannot upgrade the firmware, contact us.
Feb 01, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Mi impresora kodak Esp 5 Muestra en su pantalla " error de la impresora" Código de errro 6202" ¿Qué hago?
To quote Shockwave727:
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Sep 28, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
My Kodak ESP 7250 has been working fine but suddenly came up with Error code 6202.
Possible ink cartidge level being less.
Open the printer properties to check on the levels. If not remove the printer and connect once again affer shutting down PC.
If this wont work then remove printer, uninstall and reinstall, then connect to check if the printer is detected and installed.
If not drives are jammed/ the main board has errors..
Sep 12, 2010 | Office Equipment & Supplies
Scanner motor move failed error code 6202
to solve this
-Unplug power cable
Nov 07, 2009 | Kodak ESP 5 Printer
134 people viewed this question
k24674
jasbo
jasbo
