Question about Brother HL 5250DN Laser Printer
Toner light comes on and status light is red after replacing toner cartridge.
I know this is an ancient thread, but here is my solution to this problem:
Open the printer and remove the toner cartridge. Inside the printer, on the left hand side, is a little lever that lets the printer know there is a cartridge inside. Push the lever down, and secure it with a piece of tape. Close the printer and power it up. You should get to the point where the red light stays on. Open the printer, remove the tape, and replace the cartridge. The printer will run through its cycle, and the status light should turn green. The printer should now work as normal.
I know it sounds weird, but I came across this after HOURS of messing around with the printer. It has worked for me every time I have run into this situation.
Posted on Sep 08, 2013
Posted on Oct 20, 2010
4 Suggested Answers
  • 10 Answers
SOURCE: Brother HL-5140, Status light is red and toner
It is very hard to find the reset instructions on the Brother Solutions site.
  1. Turn the printer off.
  2. Press and hold the Go button on the front of the printer, at the same time turn the printer power on.
  3. When the Toner light is on by itself, release the Go button.
  4. Push and hold the Go button again, release the Go button when the Paper light is on by itself.
Posted on Apr 21, 2009
  • 214 Answers
SOURCE: red status light on. won't print,
Try this.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000071/HL5100_UG_ENG_3.pdf
Posted on May 01, 2009
  • 20 Answers
SOURCE: My Brother HL5250DN shows toner light on (yellow)
Try this..
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Posted on Mar 05, 2011
When the printer is turned on, it warms up and then the red status button comes on. I've install new toner cartridges, dumped the waste toner tank, installed a new usb cable, in a different slot, and...
There is a lot of problems that can cause the red light to come on, toner cartridge problems, waste toner tank full, paper jam. The only way to know for sure is to check the smart panel software to see what the printer is reporting as the problem, then you can attempt to fix it.
Jun 29, 2011 | Samsung CLP 300 Laser Printer
How do I check my toner levels
Your printer had a LED indicator located on the Top, Right side panel of your printer.
When the Toner LED, on the control panel, indicating each individual toner cartridge according to its color, lights, and the Status LED lights red, the toner cartridge is totally exhausted. Your printer stops printing and you need to replace the Toner.
For more information about your printer, click on the link.
I hope this will be able to help you.
Thank you for using Fixya
Mar 16, 2011 | Samsung CLP 300 Laser Printer
Why is red light on samsung clp- 315 and it is not printing
Does one of these situations apply to you?
The Status LED light is Red and the Toner lights are OFF (Check Smart Panel for message)
  • A Paper Jam has occurred.
  • The Front, Top, or Back Cover is open.
  • There is no paper in the Paper Tray.
  • There is a problem with the Waste Toner container.
  • A major error has occured.
The Status LED light is Blinking/Flashing Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Can still be used to print, but quality is unreliable)
The Status LED light is Red and the Toner light(s) are Red
  • The Toner cartridge(s) that are Red need to be replaced. (Printing is not available)
  • The Toner cartridge(s) are not installed properly.
Source: samsung troubleshooting guide for CLP-315
Sep 25, 2010 | Samsung CLP 315 Laser Printer
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
Status light goes green when power on, but then turns red and cannot print - replaced toner cartridge- not sure what the reason for the red error light is?
You have to reset your printer with a module or replace chip when you refill toner cartridges.
www.nakshatraworld.com
Jan 07, 2010 | Samsung CLP 300 Laser Printer
My samsung 315 clp has status LED red light on.
It is a color laser printer.it has 4 toner cartridge(1)black(2)magenta(3)cyan(4)yellow all cartridge is missing or toner finished.Please purchase full set toner.All toner cartridge has a image sensor.When toner is run out then it is out of work.
Dec 14, 2009 | Samsung CLP 315 Laser Printer
My Brother HL5250DN shows toner light on (yellow) and status light on (red) even after toner cartridge replaced with new one. Already tried reset by holding down go button. Is the printer dead?
Try this..
Oct 07, 2009 | Brother HL 5250DN Laser Printer
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
It doesnt print anything. the status light is red. i dont know whats wrong
A red Status light means 'paper jam'. A red light corresponding to one or more of the toner cartridges means empty cartridge. A flashing red light corresponding to one or more toner cartridges means low toner.
Aug 27, 2009 | Samsung CLP 300 Laser Printer
Status red and amber Toner light
This problem you are getting is to replace the toner cartridge. Have you recently changed the drum unit as well. If so exchange it back to the other one.
After installing new toner or full toner cartridge and removing the yellow plastic cover press the go button this should start the printer on a cycle and add the toner. If this doesn't work then the toner sensor has malfunctioned and will need replacing. This will in turn out way the cost of a new machine.
Hope this helps and not too late for you.
Thanks Jason
Aug 09, 2008 | Brother HL-5240 Laser Printer
Brother HL 5250DN Laser Printer Logo
527 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
