Question about Weather King 10AJA6001AH Air Conditioner
No power to the thermastat - Weather King 10AJA6001AH Air Conditioner
  • Weather King Master
  • 43,501 Answers
There is either no power to the air handler or the transformer has burned out...
The power to the t-stat comes from there....if your lucky the transformer is fused and the fuse has blown...if you replace it and it blows again then check for a short in the low voltage...
Hereis a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Oct 12, 2010
  • Kenneth Archibald Oct 15, 2010
    If your system has a safety switch on the drainline and your drainline is clogged, it could be wired to shut of power to the t-stat.
When i trun the thermastat on the fuses blows if i leave the thermastat in off position the fuses dont blow if i disconnect the red wire from air handler and the a/c it dont blow
Fault is on your unit , Thermostat is off , then most lilkly to unit , so no power, fuse will no blow ! Don't disconnect ,wires unless you know what you are doing.
Mar 16, 2015 | Heating & Cooling
No Power to Duo-Term Thermastat
Can you give me model #'s of thermostat & AC unit, as well as upper unit? Number of or at least a description of thermostat, and numbers for ceiling assy should be visible when filter taken off, as well as # for upper unit should be tagged on bottom of unit on roof.
Jul 17, 2009 | Heating & Cooling
Thermostat
Heat pump Thermastats have Terminals RYW/OW2 G C. I run into this a lot with people buying tStats at home depot. To wire three sages of heat you must have correct tstat. one stage cool and three stage heat. You have to have enough wires at the Tstat. I use white first stage brown second and grey or black third. Make a diagram where each wire goes. Remember to trun of air handler power or you will short the transformer or blow low voltage fuse. Yellow cool, green fan, most of the time blue is c unless it is a battery tstat. orange is O. Red R ot power wire. Rusty
Jun 03, 2009 | Heating & Cooling
1995 toyota 4runner gets hot with new thermastat gasket
the thermostat should be closed when you take it out, therefore the thermostat is bad. It does not closed.
May 22, 2009 | 1995 Toyota 4Runner
Honeywell HZ517 Electric Baseboard Heater not powering up
first.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Feb 09, 2009 | Honeywell HZ517 Baseboard Heater
Ac heat carrier thermastat model no.hh01ad042
GOto the iside unit itself. and remove the door and look for a terminial strip that the thermostat wires from the thermostat connects to and write down the colors wires and the letters they're connected to and connect the same to the thermostat .... they should be... r--red=power w-white=heat y--yellow=cool g-- green=fan! See which wires/ colors they're not using and bend back! Thank-you-very-much!
Aug 31, 2008 | Heating & Cooling
Blank Thermastat LCD
check power to the furnace.
Aug 10, 2008 | Carrier 38CKC036 Air Conditioner
Refrigerator blowing warm air.
check the thermastat with power off remove one wire on the thermastat and read across the two terminals of the thermastat with an ohm or resistance meter if set to highest setting on the thermastat you should get a resistance reading if you don not the thermastat is vad
May 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Thermastat malfunction
Generally speaking; R terminal to Y terminal on the back plate. However you may have a transformer problem which would not give you power to the R terminal in the first place. Jumpering R to Y should make the outside condensing unit come on if you have power.
May 08, 2008 | Heating & Cooling
Weather King 10AJA6001AH Air Conditioner Logo
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
