Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a john deere sabra that will not move in any gear. The drive belt and the transmission pulley are moving but the transmission does not engage and the wheel axles are not moving. what is the problem?
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
SOURCE: John Deere Lt 166 ride on mower
jd lt 166 has 5 different decks
3 of which have the same belt routing
1st the belt needs to be adjusted correctly to stop it from "slacking off"
then on most decks the belt is routed in between the 2 small idler pulleys and then to the engine pulley
so let me know the deck i.e. 36", 42 ", 46", 48"
different belt sizes also
kendo
Posted on Jun 21, 2009
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
bbreton
  • 437 Answers
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Posted on Oct 14, 2009
Mower blades move but no gears forward or back, very suddenly quit.
Rex, check the drive belt,old stretched, loose, broke, fell out of position Tension er weak or seized if equipped, worn out pulleys.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tightening the belt on John Deere L110 Tractor
https://jdagccc.custhelp.com/app/answers/detail/a_id/428/~/mower-belt-comes-off---100-series
How to Adjust John Deere Drive Belt
John Deere Fail LA145
Apr 23, 2016 | John Deere L100 Series
Travel pedals do not engage.
Things to check out. 1. That there is oil in the drive unit. Is there a reservoir on top and can you find a dipstick? A reservoir should be half full at least. 2. Is the disengage lever or rod pushed in? Look to the rear of the machine frame and low down. This disengages a valve to enable the machine to be moved without the motor running. If in the open position the drive will not work. 3. Check that the belt is driving the pulley on the top of the transmission. This normally has a tensioner which automatically takes up the slack. A worn belt can slip or jump off the pulleys. Look at the motor drive pulley to ensure that the belt is still on it. This is NOT the bottom one which drives the deck and has an electric clutch.
Oct 09, 2014 | John Deere Replacement Hydrostatic...
Belt slipped off Transmission Pulley of John Deere D110. How to get the belt keeper aside and put the belt back on the pulley?
There are usually two bolts securing the keeper to the bottom of the tractor. remove one and loosen the other and you should be able to swing it out of your way. worst case is to take them both out and replace the belt and reinstall the keeper
Aug 25, 2014 | John Deere Riding Lawn Mower. D110 42 in....
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
John deere stx38 wont move transmission locked up?
Jul 14, 2009 | John Deere Garden
The rear end on my 1987 750 4wd john deere quit working yesterday, it will still go forward when i step on the lever to engage and lock both back tires but will not move unless i do, front end works fine,...
Check first to see if the drive belt has jumped off a pulley or the belt is stretched or broken. Next if there is a grinding noise it means the transmission has a broken or chewed up gear.
Jun 24, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
95 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
