Question about Sport & Outdoor - Others
My beeman hw 30 air rifle is cocked but will not shoot..yes the safety is off...it seems that the safety or trigger mech is out of adjustment inside. Is there a safe way to fix it?
  • 3 Answers
There is probably a safety on the bolt as well, make sure the bolt is all the way in the closed position.
Posted on Oct 12, 2010
  • tgreer630 Oct 12, 2010
    no bolt on that model..its a break down
Beeman air rifle no air pressure
Break Barrel Air Rifle Maintenance Part 1
Beeman Marksman
This might call for seals replacement. Don't lube these parts without confirmation of what to use at Beeman.
Aug 28, 2017 | Beeman Optics
Beemans sportsman rs2 trigger system not engaging after the break barrel been bend goes blank
Do you mean that you have never been able to cock the rifle ever
Like get the piston to lock up to the sear if so
Return to where you purchased it and get them to sort it
Mar 17, 2015 | Optics
How do tighten / secure the barrel to the stock of my Beeman air rifle R9
It is a break barrel and if you secure it to the stock how will you cock it
Sep 07, 2014 | Beeman R9 Air Rifle, No Sights - 0.177...
How to tell if i bent my r1 carbine barrel
If it was zeroed before the mishap try shooting a target to see if point of impact has changed if so decide to repair or replace damaged parts
Apr 01, 2014 | Beeman R1 Supermagnum Air Rifle, No Sights...
Gammo pellet rifle cocked and will not fire
Check to make sure the safety is not on. Check for an obstruction in the trigger mech. Check to ensure that the barrel is locked closed.
Nov 28, 2013 | Optics
I have a 'used' Beeman Sportsman 1000 Series rifle (no scope). Have a pellet in the rifle (it's been in there for about a year, heh), I'm moving the lever-near-trigger back and forth but rifle won't shoot...
If your pumping the rifle and you hear air seeping out then the seal on your air chamber is bad or got pushed from where it is suppose to be, you can take it apart and see, its real simple...
Aug 03, 2013 | Beeman SS1000T Sportsmans Series .177...
I have a beeman rs1 chinease air rifle is the trigger adjustable and if so How?
Yes they are adjustable, both 1st and 2nd stage and also trigger weight.
The trigger group is easily disassebled and honed with fine emery paper. You really dont need a mirror surface but the factory surface is very far from smooth. There are som sharp corners on the sear and the trigger lever, DO NOT ROUND THEM.
Pay close attention to the three small springs inside, if you get them mixed up the rifle will not lock.
This work will make all the difference in your rifle.
Just work slowly and with caution not to change the angles in the trigger geometry, all you want to do is polish the surface.
Tutorial can be found here http://webpages.charter.net/guru1/documents/RSE%20Airguns%20-%20Beeman%20RS2%20trigger%20guide.pdf
Mar 21, 2010 | Beeman Optics
My Beeman RX-1 will not lock upon cocking. I was
Check the trigger guard screws. If the trigger guard has been loosened or removed, it can effect the proper position of the safety actuating lever (the lever in front of the trigger adjustment screw), preventing a full cocking stroke.
Jan 11, 2010 | Optics
Beeman air rifle wont latch when cocking
you have a triger fault its not locking the piston back best and safest bet is a gun smith,, never play with a triger if your not good with guns,
Dec 25, 2009 | Beeman 1024 Takedown Rifle, Scope, Rings &...
Sport & Outdoor - Others Logo
100 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
