Question about HP Photosmart C6100 All-In-One Printer
It wont print in Black and when press the colour menu in copy menu only orange color is coming and the letter are not showing
  • HP Master
  • 7,733 Answers
Change the black cartridge!
Posted on Oct 12, 2010
Printer ink doesn't appear to be dry on colour printing.
Dripping is impossible with laser as the toner is dry. A bad cartridge may cause the color shift. Print the demo page to confirm whether the problem is the printer or your program. Remanufactured cartridges provide very poor results with this model of HP.
Jun 24, 2015 | HP LaserJet Pro 300 color MFP M375nw
How do I clean my Brother MFC 210C. I've done it before ont eh computer, but can't find where to do it this time.
Press the Ink or Ink Management key on the control panel of the machine. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set. Press Color (Colour) Start. The machine begins printing the Print Quality Test Sheet. By reviewing this Test Sheet, you can determine if the print quality needs improvement. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
The display will then show START CLEANING? 1.YES 2. NO. Press 1 (YES) and the machine will start cleaning the color ink cartridges.
Jan 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
MFC-490CW two ink colours just not printing, it still prints biut just with black and blue, tried cleaning them the normal way but they still wont print. Cant get into maintenence mode to try better...
Powerful cleaning is: Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode (all lights will flash).
press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Nov 10, 2009 | Brother MFC 210C All-In-One InkJet Printer
HP c3180 color printing problems
I would definitely start by printing a self-test page. With your model press and hold the Cancel button and then press the Start Color Copy button and then release both buttons. When this page comes out you should be able to identify the 4 different color sections...black, cyan, magenta and yellow. If any of these seperate areas are choppy or non-existant, you need to replace your cartridge. Here is a link that will show you examples of what you should/shouldn't see on the self-test report.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00661556&lc=en&dlc=en&cc=us&product=1146331&rule=25470&lang=en
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
Jagged edges and misregistration
What printer is it ? Some older ones need manual calibration, where patterns are printed, then you tell the system which is the best one. Newer ones can self calibrate, but still need it done. Go into your printers menu and see if you can find something on calibration or allignment.
Jul 18, 2017 | Konica Minolta bizhub 350 All-In-One Laser...
My copy prints come out blurry after changing ink cartiges
Try this:
Checking the print quality:
  1. Press the Ink or Ink Management key on the control panel.
  2. Press the up or down navigation key to select TEST PRINT and press Menu/Set or Set.
  3. Press the up or down navigation key to select PRINT QUALITY and press Menu/Set or Set.
  4. Press Color (Colour) Start. The MFC/DCP begins printing the Print Quality Test Sheet.
  5. By reviewing this Test Sheet, you can determine if the print quality needs improvement.
  6. Closely examine the print quality of the four color blocks that are formed by short diagonal lines on the Test Sheet.
    If all lines are clear and visible, press 1 (YES) and press Stop/Exit.
    If you can see missing short lines, press 2 (NO) and go to Step 7.
  7. The display will then ask you if the print quality is OK for black and three colors. Press 2 (NO) for black or three colors with the problem.
  8. The display will then show START CLEANING? 1.YES 2. NO.
    Press 1 (YES) and the MFC will start cleaning the color ink cartridges.
  9. After the cleaning is finished, press Color (Colour) Start. The MFC/DCP will print another Print Quality Test Sheet.
  10. If you can see missing short lines in any of the four color blocks press 2 (NO) and repeat the quality check and cleaning process. Repeat this procedure at least 5 times if print quality remains a problem. If short lines are still missing after the fifth cleaning and test print, replace the necessary ink cartridges. If the print quality of the 4 color blocks is OK, press 1 (YES).
Setting the Alignment:
  3. Press the up or down navigation key to select ALIGNMENT and press Menu/Set or Set.
  4. Press Black (Mono) Start or Color (Colour) Start. The MFC/DCP begins printing the Alignment Check Sheet.
  5. By reviewing this Test Sheet, you can determine if the alignment needs adjustment.
  6. Examine the 600 DPI and 1200 DPI test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 DPI and 1200 DPI most closely matches the 0 sample, press 1 (YES).
    If one of the other samples is a better match for the 0 sample, press 2 (NO). The display will then prompt you to select the sample that most closely matches the 0 sample for 600 DPI and then 1200 DPI.
  7. Press Stop/Exit.
    If I could be of further assistance, let me know. If this helps or solves the issue, please RATE it.
    Thanks, Joe
Oct 11, 2008 | Brother MFC 420CN All-In-One InkJet...
Copy problems
try to adjust color saturation :
Press Menu/Set, 3, 4.
2 Press ▲ or ▼ to select Red, Green or Blue.
Press Menu/Set.
3 Press ▲ to increase the colour saturation.
—OR—
Press ▼ to decrease the colour saturation.
Press Menu/Set.
4 Return to Step 2 to select the next colour.
—OR—
Press Stop/Exit.
Jun 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon pixmaip2200
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Oct 25, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer Logo
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
