Question about Kenwood KM305 Stand Mixer
My balloon whisk does not touch the sides of the bowl so the butter stays up on the sides whilst only a little gets mixed in the middle. I have adjusted the nut on the whisk and it seems to be a bit better but I am scared to tinker too far and do my machine a damage!
Kenwood chef keeps curdling eggs
Put water in Kenwood and a bowl inside the Kenwood to hold eggs. Eggs need to be done SLOWLY. Can also add a LITTLE water to aggs as they cook to slow down curdling . Basically you need to turn Kenwood into a double boiler. Lift bowl with eggs in and out of Kenwood to control temperature and whisk away now under control. Lift bowl and cool and slow down cooking and lower back in water and Kenwood to hear back up. Keep whisking and lift and lower bowl as needed. Some melted butter doesn't hurt either!
Jan 11, 2015 | Kenwood Food Mixers
Kitchenaid whisk will no longer slip past the locking pin to rotate and attach on the spindle.
this might help... the whisk has a slightly larger whole then the other attachments. it is also inset. there is a washer that holds the spring on. if that is slightly off or bent it won't sit in the Whisks inset right. look a little closer to that and the spring. if there happened to be dried on food that could be the slight difference that can prevent it from staying one. Hope this helps!!!
25298509-2el2bftwapqh2uesegcwr3xp-2-0.jpg 25298509-2el2bftwapqh2uesegcwr3xp-2-1.jpg
Nov 27, 2014 | KitchenAid Professional 620 6-quart...
Beater on Kitchen Aid stand mixer doesn't touch bottom of bowl
Why would you raise the beater if you want it to reach the bottom of the bowl? You need to lower the beater. Turn the screw in until it just touches with empty bowl on high speed then turn it counter clockwise a 1/4 turn so it will just clear.
Mar 16, 2014 | KitchenAid KSM150PS Artisan Series Stand...
When raised to do whipping my professional 550 hd mixer attachment does not scrap the bowl to mix properly
You can adjust the mixer bowl up and down slightly. If you lower your bowl and look at the back you will see a little screw, it looks like a flat head screw and it is on the "neck" of the mixer.
You can raise and lower the bowl by adjusting this cam screw. You can tell that your bowl is adjust correctly by attaching the flat beater and put a dime in the bottom of the bowl, the beater should just barely touch the dime and move it around the bottom of the bowl.
The beater will not scrape the sides of the bowl, if you are wanting the sides of the bowl scraped I would recommend the Flex Edge Beater made by KitchenAid which is basically a flat beater with a rubberized edge which will scrape the side of the bowl as it rotates.
Here is a link to the flex edge beater on our website: http://www.mendingshed.com/kfe6l.html
Let me know if you have any other questions.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
I have a Sunbeam Heritage Series Mixmaster, 350 Watts, just purchased yesterday. I used it to mix cake batter, cream butter, whip egg whites....the problem is that it doesn't blend the ingredients. The...
There should be a small lever on the base in front of and below the bowl. It will move to 2 positions. It sounds like you have it set for the small bowl but are using the large bowl. Press down on the lever and move it to the other side. If I'm right, that should correct the problem.
Oct 26, 2009 | Sunbeam Heritage 2346 Stand Mixer
My Professional HD Kitchen Aid doesn't mix all of the ingriedienc
One thing many KitchenAid mixer owners complain about is that it's difficult to scrape the bowl while the mixer is running. Because the beater rotates around the inside of the bowl, and because the beater doesn't actually touch the bowl, you have to stop the mixer frequently to scrape the sides of the bowl to make sure all the ingredients are well incorporated.
Two companies have come up with fixes for that problem -- the BeaterBlade+ and the SideSwipe.
They are available for most KA mixers. Cook's Magazine tested both in January 2009 and liked the SideSwipe a tad more than the BeaterBlade because they thought it performed a little better on a particularly heavy cookie dough, but one reviewer on another forum commented that dough tends to bunch up on the SideSwipe's inner parts.
In any case, I have the BeaterBlade+, mainly because it was available from Amazon for $30, no tax, free shipping, and I didn't feel like driving around to find the other.
Both are made of very strong plastic and have silicone scrapers on the edges of the blades. The scrapers do touch the bowl and thus provide a constant scraping of the ingredients, assuring that everything gets mixed in. I've found that I rarely have to stop the mixer, except to make sure that the ingredients that cling to the beater itself are mixed in.
Jul 09, 2009 | KitchenAid Food Mixers
Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Oct 29, 2008 | Food Mixers
SILLY QUESTION
Push the whisk attachment post up into the mixer, turn counter-clockwise and it should lock into position.
Apr 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
Incomplete mixing
You need to raise the bowl just a little less than the thickness of the layer presently being left behind. Too much and the beaters will touch the bowl .
Jan 31, 2007 | Bosch 700 Watts MUM7010 Concept Series...
Kenwood KM305 Stand Mixer Logo
146 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
