Owners manual for kenmore 80 series washing machine
    President:
  • 1,937 Answers
See the following site:
http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu
Enter your model number and you should be able to get PDF versions of the manual.
Posted on Oct 12, 2010
SolutionGuy
  • 331 Answers
SOURCE: Need to remove the back panel off of the Kenmore series 80
Don't do that, Mike! Access is from the front...
SG
Posted on Apr 07, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosned, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Nov 02, 2007
SOURCE: kenmore 80 series washing machine
I have Kenwore Series 80 Clothes Washer, Model # 110.26842694,Serial # CJ 3231197 and a couple of problems exist; as the timer reaches the rinse cyle the timer stops and needs to be set to the spin setting, during this period the water does not drain. Is there any suggestions for repair that can be advised. Thanks, Darius Caswell
Posted on Nov 21, 2008
  • 1028 Answers
SOURCE: Kenmore 80 Series Top Load Washer not agitating
if it will pump out ckd motor to gearcase coupling probably broke
Posted on Sep 03, 2008
jsrock516
  • 5911 Answers
The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch DOES require replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 11, 2009
We want a shop manual for Kenmore 80 Series top-loading clothes washer
You could try this: http://www.repairclinic.com/Kenmore-Washing-Machine-Model-11026832692-ID-501837-Manuals-Care-Guides-Literature-Parts
It sounds like the belt or motor may have gone. Belts are pretty straightforward, I've replaced a couple over the years. The motor will take a bit more work. I also resolved such an issue by opening the electronics panel at the top of the machine and reseating all the connections.
Dec 19, 2013 | managemylife.com
Kenmore 80 series washing machine manual
how do I replace the speeds switch on my series 80 washer??
Sep 24, 2010 | Washing Machines
Kenmore 80 series washing machine model stopped spinning
Check this out acc8ce4.jpgmight be a partially defective coupling or lid switch. More HERE
Mar 21, 2010 | Kenmore Washing Machines
Kenmore Series 80 washing machine won't drain after wash cycle. The machine just stops.
Check the lid switch under the edge of the top where the lid closes. When you are about 1 inch from closing the lid you should here a little click sound. That is the switch closing. I fyou do not here the click then the switch is bad.
Sep 01, 2009 | Kenmore Washing Machines
What is the cu ft capacity of a Kenmore Series 80 ''capacity plus'' washing machine? Thanks
The capacity of the Kenmore 80 series is 3.0 cubic foot. The 90 series washer is 3.2 cubic foot.
Jul 16, 2009 | Washing Machines
Looking for a Kenmore washer manual
The following link explains step-by-step how to replace the lid switch on a Kenmore Top loader:
This is a simple repair. If you have any questions, or need additional assistance, please let me know.
Apr 03, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
6,945 people viewed this question
Top Washing Machines Experts
